20 Most Recent
GMC Denali 700C Road Bike Questions & Answers
Why does the expander on my handle bars always come loose
Remove the bolt and put a lock washer between the bolt and head. That or put some blue loctite on the threads. Just remember to have the head removed from the fork tube before the bolt comes out or the expander will come off in the forks.
Replace brakes for denali 700c
just go to a higher end brake pad that should work.First make sure the cable is adjusted properly, that could be the whole problem. Maybe you're just used to the bike now and are going a lot faster than you used to.
Where do you to install frame pump?
Thats were they go ,is and unscrew / screw back up .take water bottle cage out ,put the bracket for the pump,in top put your water cage ,put bolts back in , secure it and u should be good.the only reason you shouldn't be able to fit it ,is because is not for a bicycle .
