20 Most Recent
Razor Fz 2000 20-Inch Freestyle Bike Questions & Answers
Which way round
you place it between 1and 2 or at the end of the of the sprocket don't worry about that just install it
Front fork too narrow to fit tire
sounds like the box may have been squashed. send it back to where you got it from or its not that hard to spread the forks apart by pulling them. used to do this all the time when servicing mountain style bikes that have been thrashed by customers :)
Trying to assemble my bike
the pegs screw onto the threads of the wheel spindle. as for breaks that's a little harder. there are different kinds of breaks, coaster cantilever and disk breaks. ill need more info on the bike model so i can tell you how to adjust the breaks.
I need to know how to attach brake cables to the brakes
there should be (for lack of a better desciption) a round metal "plug" on the end of the brake cable where it attacheds to the lever. it hooks into the lever and there should be an adjustment further down to the caliper to adjust it.
Brakes and pegs
There is two ways to put the pegs on.
1. they screw on th the threads of the wheels where it mounts to the frame.
2. If there is just a hole in the peg you have to remove the nut where the tire mounts to the frame put the peg on then put the nut back on the wheel. You will need a long extension for your socket for this method.
Good Luck
