20 Most Recent Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Questions & Answers
3answers
Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same problem. The agitator stopped turning after I sucked up a foreign object (my wife's watch) and it got jammed in the intake. After removal of the watch the agitator did not spin when turning on the machine, and the reset button never deployed (it remained buried in its housing and would not depress with a paper clip). The agitator was not bound and I could manually move it in both directions with ease. Faced with prospect of paying $125 or more for a repair, a good sharp kick to the chassis from the top promptly fixed the problem. I have found that kicking malfunctioning electronics often works.
7/6/2021 4:09:12 AM • Kenmore 31913... • Answered on Jul 06, 2021
2answers
Why is there no air blowing into the dust bag ?
You can purchase the replacement kenmore ef1 filters from Govacuum with an exclusive 11% discount coupon for Fixya.com readers, use code: FIXYA11. We also offer free shipping over $35. https://www.govacuum.com/products/kenmore-ef-1-exhaust-hepa-filter-2-pack-similar-to-86889-40324-ef1-panasonic-part-mc-v199h-by-zvac Jeethu Govacuum Team https://www.govacuum.com
9/17/2017 3:17:43 PM • Kenmore 31913... • Answered on Sep 17, 2017
Sears 116.31913 Lower units, vacuum motor and
Open in the power cord to them
7/15/2017 1:08:34 AM • Kenmore 31913... • Answered on Jul 15, 2017
Manual for Kenmore Progressive Direct Drive
can some one show via picture of the location where the micro switch is where the hose attaches to the progrssive direct drive vacuum cleaner to get the start brushes rolling again,
12/29/2016 1:07:38 AM • Kenmore 31913... • Answered on Dec 29, 2016
Beater brush will not spin and head drops down without using foot release
You didn't provide the model number so couldn't look it uo, but sOme of the progressive uprights have a circuit breaker on, it will trip when something catches on the brush roll, push it to see if it will reset, if there isn't one, get me the model, it will start 116.*********
9/20/2015 12:52:57 AM • Kenmore 31913... • Answered on Sep 20, 2015
2answers
Why did the agitator stop?
Bryan, Most of the time, when a brush stops, you either have a broken belt or there is something wrong with the brush. If the brush spins very freely when you try spinning it by hand, you have a broken belt.
7/25/2015 11:24:24 PM • Kenmore 31913... • Answered on Jul 25, 2015
Why did the brush roller stop spinning?
With the cleaner unplugged, turn the unit over and look inside the opening where the brush is located. Do you see the clogging of the brush with lots of hair? If so, you will need to disassemble it to remove the hair. In any case, you will probably need to take off the cover to see if there is an obstruction jamming the brush. Also, check to make sure that motor for the brush is getting power. If there is an electrical cable on the outside connecting the brush housing to the rest of the vacuum cleaner, check if it is disconnected. When you have the cleaner on, do the lights glow? Do you hear the motor running? Try the above and report back.
7/21/2015 4:43:22 PM • Kenmore 31913... • Answered on Jul 21, 2015
2answers
Kenmore agitator brush does not spin
sounds like ya need to replace belt.
7/21/2015 4:36:11 PM • Kenmore 31913... • Answered on Jul 21, 2015
2answers
Kenmore progressive vaccum lost suction
For the canister-style vacuum with the long hose, you can't see all the way thru it, since the plastic fittings on the ends are curved. Mine was clogged - I mean, really clogged! Others have suggested using a high-powered air compressor to blow it out, but I augured out my lint/hair/straw/other-unidentifiable-stuff clog with a manual (hand-crank) home sink/drain auger. Worked like a charm! Use a small mirror (like a dental mirror) and a flashlight to see a little ways into the hose if you want. Finally, run the auger all the way thru to make sure you push out anything you couldn't spear and pull out.
1/26/2015 8:40:41 PM • Kenmore 31913... • Answered on Jan 26, 2015
Brush will not turn on vaccumm
They do not sell any replacement parts on that Nozzle as far as I know when they did part was super expensive
5/29/2014 11:29:23 AM • Kenmore 31913... • Answered on May 29, 2014
2answers
I just inherited a Kenmore
http://www.managemylife.com/mmh/owner_manuals/6826/KENMORE-Vacuum-Upright-L0403208
5/4/2014 1:50:43 AM • Kenmore 31913... • Answered on May 04, 2014
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
184 questions posted
Top Kenmore Vacuums Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Vacuums
  • Kenmore Vacuums
Most Popular Question
just inherited kenmore
  • Vacuums
