20 Most Recent Airstrike Bell 1800 Floor Bike Pump Questions & Answers
Airstrike Bell 1900 , the hose is ripped. What do
Always a good idea to contact the manufacturer: The Bell Garage or a bike shop may be able to help. The pump may accept a different brand hose. I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
5/8/2017 2:28:07 AM • Airstrike Bell ... • Answered on May 08, 2017
0answers
I have a "Judge"
Sure, A new O-ring and a little grease, the same you use on your bearings to make a good seal.
Without seeing and feeling the actual pump, a sloppy O-ring will cause a loss of pressure.
You will also want to check the head and make sure the rubber still makes a seal around the tube valve, if not then that will need to be replaced as well.
3/20/2011 8:51:37 PM • Airstrike Bell ... • Answered on Mar 20, 2011
The tubing that leads from
Most Bike Shops carry repair kits for common pump brands and I wouldn't be surprised if some cross brand parts would work. eBay has many for sale.
"floor pump hose"
You might even be able to go to an automotive supply store and get some pressure hose yourself real cheap.
3/13/2011 10:23:34 PM • Airstrike Bell ... • Answered on Mar 13, 2011
Where Can I get a new hose for my Bell AIRSTRIKE
Go to ebay.com
3/13/2011 1:52:04 PM • Airstrike Bell ... • Answered on Mar 13, 2011
How do I use the Bell AirStrike Digital Floor Pump
The gauge measures three different amounts. Be certain that you have it set to PSI. Then set the target PSI. The green LED indicator will then flash when you are within 5 PSI of your target and will flash constant when the target PSI is reached.
8/30/2010 2:01:10 PM • Airstrike Bell ... • Answered on Aug 30, 2010
Need new hose
Has anyone found a replacement hose for the Airstrike 1900? And/or instructions on how to replace it?
8/3/2010 4:17:18 AM • Airstrike Bell ... • Answered on Aug 03, 2010
Should I add oil to the top opening (where pump
It's not the opening that is the culprit. Those bell bicycle pumps have an o-ring for a piston seal, and this ring needs oil from time to time. The oil that should be used is as thin an oil as you can find, something like 3 in 1. You should disassemble it to check to see if the plastic piston isn't cracked. (They do crack from time to time, and might be what is wrong with your pump.)
11/25/2009 10:28:56 PM • Airstrike Bell ... • Answered on Nov 25, 2009
2answers
What size is the seat post on the Next px 6.0 bicycle?
The Next PX 6.0 uses a 27.2mm seat post.
1/1/2024 12:50:08 PM • Cycling • Answered on Jan 01, 2024
My gt mach one serial number is SA8Y01976 NEED TO KNOW THE YEAR AND WHERE WAS MADE
serial number is 12900243GT m one. Can anyone tell me the year?
10/24/2023 4:03:47 PM • Cycling • Answered on Oct 24, 2023
3answers
Where can i get a left paddle for my Mongoose XR-75 Mnt. bike?
clean your garage and you will have it. or try bike shops.
10/5/2023 4:17:26 PM • Cycling • Answered on Oct 05, 2023
My bicycle's pedal moves before the wheel. I tried reassembling the chain and the wheel. P.s my bicycle doesn't have a mechanical gear
If your bicycle doesn't have mechanical gears, the issue might be related to the freewheel or cassette, depending on your bike's specific setup.
10/3/2023 10:24:25 AM • Cycling • Answered on Oct 03, 2023
Tomahawk E Series Exercise bike loud peddling sound
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube. This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
9/22/2023 12:16:04 PM • Cycling • Answered on Sep 22, 2023
Airstrike Bell  1800 Floor Bike Pump Logo
21 questions posted
Top Airstrike Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you an Airstrike Cycling Expert? Answer questions, earn points and help others
View Most Popular
Airstrike Cycling
  • Airstrike Cycling
Most Popular Question
judge
  • Cycling
