20 Most Recent
Kenmore 23613 Progressive PowerMate Bagged Canister Vacuum Questions & Answers
I have a kenmore progressinve
Usually when you remove the hose from the swivel base and try to attach the new hose the attachment is usually not tight enough therefore the suction is always low. It is better for you to purchase the swivel head parts to enable you enjoy the use of the vacuum more. If you simply replace the hose then there is a probability that the connection might not be so airtight therefore suction becomes low and the vacuum's effectiveness would be poor. So simply get the swivel head and if possible get one already attached to a hose.
Hope this solution has been helpful?
It wont start
Hello and Welcome to FixYa!
Please provide us with a bit more details of the scenario, and also provide us with the make and model of your device... That might be due to improper power connections, any power failure or bad/shorted circuitry.. That's why, a more wider picture of the scenario is required.
Concerned..
How do i separate the pipe,suction from the
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider
the savings that can be had when an informed Expert can save you a $100
service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If
you don't want to pay - feel free to re-submit your question so it
returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Broken power head belt
Not sure which one you have, need complete model number. You can go tosears.com, click on the parts link, enter you model number, click on the powerehead link. A parts list will come up along with a picture breakdown of it.
Alot of them the part covering the light is just snapped into place, push in on the side andback to release it. Remove the 2 screws, use a flatblade and stick in the slot on each side from the bottom and pry up to release it.
The other type, you tak out the 2 screws from the bottom, then on the back and each side are release tabs that you pry out to release.
Brush motor doesnt work
The cord at the bottom of the power head neck may be bad. But so could the plug connections in the hose handle, and the cord on the wand. Check both ends of the wand and make sure that the plug ends aren't burnt, if they are replace them and maybe the plug inside the hose handle.
Retractable cord
I'm assuming that you have bought the new retractable cord assembly. If you have so, I believe the cord should retract going counter-clock wise (pulling it makes it spin clockwise).
On/off switch needs repair
you don't have to repair the switch. your vac may have a relay inside the canister which may be defective
Removing and installing the pedal in kenmore upright vacuum cleaner - part no. 8174906; model no. 116.31912100
I don't have specific information on the Kenmore upright vacuum cleaner model number 116.31912100 or the part number 8174906, but I can provide you with general guidance on how to remove and install pedals on some vacuum cleaner models. Keep in mind that procedures may vary between models, so use the following as a general guide:
Removing the Pedal:
- Unplug the Vacuum Cleaner: Ensure the vacuum cleaner is unplugged to prevent any electrical accidents.
- Turn the Vacuum Cleaner Over: Lay the vacuum cleaner on its back so that you have easy access to the underside.
- Locate the Pedal Assembly: Identify the pedal assembly on the underside of the vacuum cleaner. It is usually connected to the height adjustment or other features.
- Release Tabs or Screws: Look for tabs or screws securing the pedal assembly in place. Use a screwdriver or the appropriate tool to release these tabs or screws.
- Disconnect Linkages: Some pedal assemblies are connected to linkages that control various functions. Disconnect any linkages carefully.
- Remove the Pedal Assembly: Once the tabs, screws, and linkages are disconnected, carefully remove the pedal assembly from its housing.
Installing the Pedal:
- Position the New Pedal: If you are replacing the pedal, position the new pedal in place.
- Reconnect Linkages: If your vacuum cleaner has linkages, reconnect them to the appropriate points on the new pedal assembly.
- Secure the Pedal: Use screws or tabs to secure the new pedal assembly in place. Make sure it is securely fastened.
- Test the Pedal: Manually operate the pedal to ensure that it moves smoothly and engages the desired function.
- Turn the Vacuum Cleaner Upright: Once the pedal is securely in place, turn the vacuum cleaner upright and plug it back in.
If you're uncertain about any steps or encounter difficulties, it's recommended to consult the user manual for your specific model or contact the manufacturer's customer support for assistance. They may provide detailed instructions or guidance tailored to your vacuum cleaner's model and part.
