20 Most Recent Toshiba Satellite M115-S3094 Notebook Questions & Answers
Hi i got a toshiba satelite m115 s3640 laptop i
I am not sure what you mean about power point. If you are speaking about the power jack and the plug in the laptop then you can replace those relatively easy. Just order one. On the other hand if it is mounted to the board inside then it is not easy. Also I find that the power jack to the power unit tends to fail now more often than the plug.
11/13/2017 2:53:11 AM • Toshiba... • Answered on Nov 13, 2017
I inherited this computer and want to change font
It could depend on what program you have open, but most document software has near the top of its window, a row where it probably says "Ariel" and size and maybe "Western". That's the font name, size and language. You can also get a huge amount of new fonts online, free. Just Google "free fonts".
9/12/2010 2:11:33 AM • Toshiba... • Answered on Sep 12, 2010
Dc jack getting hot
http://shop.ebay.com/s.html?LH_SellerWithStore=1&_nkw=m115+s3094&_arm=&_armm=
Here is a link to your power plug,,
if you talking about the box on the power plug ya they get hot!!
A week battery will make it work harder
5/16/2010 5:05:46 AM • Toshiba... • Answered on May 16, 2010
Cursor(arrow) gets hanged after starting the computer
go to start menu> click on run (winXP) or start search (winvista or win7) > type in msconfig> click ok
new pop up window
- click on startup> on the bottom part click on disable all> click ok and restart pc.
4/5/2010 5:25:58 PM • Toshiba... • Answered on Apr 05, 2010
I have a new SATA hard drive to put into a used
You problem is your memory. Try putting up the old memory and i'm sure that it will work again.
Possible Solution 1.
If you just add-up the new memory, try removing the old memory and just use the new memory because they might not have the same brand, speed, or something else.
Possible Solution 2.
If you are using only the new memory, you might want to try the old memory only and if it boots up again, you might have compatibility problem on your newly bought memory.
Hope it helps.
1/10/2010 8:59:27 AM • Toshiba... • Answered on Jan 10, 2010
I have a Toshiba Satellite M60 and it is not
on the cammera and connect directly other wise u install camera software in system
12/3/2009 4:03:44 AM • Toshiba... • Answered on Dec 03, 2009
2answers
How to reset power on password on toshiba laptop
You will have to get in touch with toshiba about it, they can remove the password but you need to provide proof of ownership, the reset will include taking apart the whole machine.
10/14/2009 3:44:41 AM • Toshiba... • Answered on Oct 14, 2009
LCD Screen colors are bad on toshiba Satellite M115-S3094
Was the screen showing all OK before you updated the driver? If so did you try backing out (uinstalling) the graphics driver? You mentioned gtaking screen cover off ... did you completely remove the screen from the laptop, including the wide connector at the top and the smaller one at the bottom, and the small one to the backlight? These connectors might be seated wrong, and you'll have to reseat them, mostly the big one at the top. Best o'luck, Moorethemerrier!
9/20/2009 10:59:25 PM • Toshiba... • Answered on Sep 20, 2009
My Toshiba Satellite M115 S3094 will not boot. It
If its not booting at all then you should understand that it may be because of any of these reasons :
  • Faulty mother-board or any module of it. You will need to replair it by any technician & its a difficult & costly task.
  • Another reason is due to damaged RAM and its most probable also. In that case you can just simply replace your RAM with a new one and its not so costly also.A better RAM will enhance your system's performance too.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
6/30/2009 3:48:18 AM • Toshiba... • Answered on Jun 30, 2009
No power to Toshiba laptop after replacing power plug
It is due fault in one of the power modules of Mother-board. This may also cause damage to your system's RAM. So please repair it as soon as possible.
6/30/2009 12:53:17 AM • Toshiba... • Answered on Jun 30, 2009
Water and e66085 ribbon
Yeah, I am sure that your computer is completely destroyed. The mobo is fried, along with your hd and every other electronic component is destroyed. It's a paper weight now.
5/27/2009 11:03:25 PM • Toshiba... • Answered on May 27, 2009
Turn on lap top no screen image
If you are running it on a battery, try connecting to power supply outlet. if nothing happens, it's time to unsrew the RAM compatment and resit them ok. Change the RAM if no image appears on the screen but not before testing with an external monitor ok. Good luck
4/28/2009 5:11:22 PM • Toshiba... • Answered on Apr 28, 2009
2answers
My toshiba laptop doesnt read SDHC card
sdhc cards are not backwards compatible with sd card slots. sd cards however are backwards compatible with sdhc card slots. newer card slots and readers are sdhc and sd ready but i'm afraid your only option is to buy a usb sdhc card reader. normally the 52 in 1 readers and ones like that work well and really don't cost a lot on ebay. the only other thing you could try is to put the sdhc card in an sdhc device (such as a camera) and link it up to the laptop that way.
4/13/2009 5:34:39 PM • Toshiba... • Answered on Apr 13, 2009
3answers
Is the product key for Microsoft office 2013 the same as all product keys for 2013 Microsoft offices that operate under laptops using windows 8.1?
The product key is associated with the MS Office 2013 software, not the specific MS Windows version of Operating System - unless the MS Office lists a minimum version of OS ie: "Windows 8.0" In this case, it would not install on Windows 7. Otherwise, you should be able to install it on Windows 7, Windows 8, or later.
2/15/2024 4:30:57 PM • Toshiba... • Answered on Feb 15, 2024
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM • Toshiba... • Answered on May 22, 2023
HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE a665-S6080
In BIOS, I made Pointing Device Enable and It has been done.
11/28/2022 9:05:08 AM • Toshiba... • Answered on Nov 28, 2022
2answers
Hello I have a Toshiba E45 B4200 and the OS is lock with a password and I don't know the password I can't use it and I don't know what to do please help me my phone number is +509(REMOVED) I have What
Question edited to remove phone number. Never do that!! We have 12 million views here a year or which 5% are scammers. Question moved from Toshiba Televisions to computers. Take it to a computer shop and they will take it apart and fix the motherboard to remove the BIOS Password.
3/22/2022 12:20:21 PM • Toshiba... • Answered on Mar 22, 2022
2answers
No picture on videos on my laptop
They are created with different encoding and Windows Media PLayer doesn't decode all so-called CODECs by default. Go to videolan.org and download the VLC media player. It can play about any video you can throw at it. VideoLAN VLC Official site Free multimedia solutions for all OS
2/13/2022 1:00:17 PM • Toshiba... • Answered on Feb 13, 2022
3answers
How to play dvd movie
use VLC it plays everything it even has extensions like subtitle downloader. VideoLAN Official page for VLC media player the Open Source video framework
11/11/2021 2:57:22 AM • Toshiba... • Answered on Nov 11, 2021
Toshiba Satellite M115-S3094 Notebook Logo
18 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
lcd screen colors bad toshiba satellite
  • Computers & Internet
