20 Most Recent Kenmore 22812 Bagged Canister Vacuum Questions & Answers
Bissell 3750 brush not moving has new belt suction
Hello, this is Ava with Think Crucial. There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance. First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing. While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all. You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Bissell I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
8/6/2017 9:43:27 PM • Kenmore 22812... • Answered on Aug 06, 2017
My progessive kenmore vac is having a buring smell coming from it. I read here on this website to check the belt but I cant even get to the belt without breaking the thing into peices. What if I break
Look under the bottom. Locate the Grill section covering the brushes. This will tilt down when opened. Try either side to see which part flips open. When open, pull the brush toward you. It will pop out in your direction. Lift out the brush along with the Belt. The belt sits in a groove and it may be soft by now. Remove it. Get a new Belt at WalMart. Slip the new belt end up and around the motor pulley and the other end around the brush pulley. The belt will tend to be very tight and need your muscles. It wont brake, so use some strength to get a good connection. When the belt is on both the motor pulley and the brush pulley, push the brush back into the chamber and lock in place. Your done.
4/3/2014 9:39:16 PM • Kenmore 22812... • Answered on Apr 03, 2014
Clogged vacuum hose
I used a snake like they sell for unclogging pipes. I can use the snake on one end to break it up. I attach the other end to my industrial wet.dry vac and **** it clean. Sometimes I cannot imagine how it fills half a five gallon bucket of dog hair and stuff.
5/10/2013 2:23:06 AM • Kenmore 22812... • Answered on May 10, 2013
Beater not working on vaccum
it may need a new belt the link below will give you full instructions how to replace it.http://www.managemylife.com/mmh/lis_pdf/OWNM/L0804135.pdf
9/19/2012 6:54:59 AM • Kenmore 22812... • Answered on Sep 19, 2012
Kenmore upright vacuum model 116.35923500.
There is a switch that tells the cleaner that the upright is locked upright and the beater bar won't spin until you depress the foot release and tilt the cleaner. This switch mount is poorly designed, its just sitting in a pocket at the pivot of the cleaner. I had to double stick tape it in the pocket to keep it from moving around and put silicone spray on the pivot. The pivot actuates the switch, but its a bad design.
  • Remove front cover, to do this, pull out the bag, remove the screws under the bag and on the outside. 12 screws total.
  • Locate switch on pivot
  • Confirm mounting of switch, re-adjust and use tape or epoxy.
  • Reassemble and test.
  • This is for a Kenmore 35923500 upright direct drive.
6/14/2010 1:55:47 AM • Kenmore 22812... • Answered on Jun 14, 2010
Brush not moving, suction working
This machine is made for Sears by Panasonic. The power head, depending on model has a "gear" / cog belt or a standard flat rubber belt. First turn the power head over and see if the brush roller turns easily, if so you do need a new belt. To access the belt you will have to remove the hood from the power head. There are 4 screws, one at each of the corners to take out. Once the hood is off you will see where the belt goes and find "teeth" in the motor shaft for the motor / brush roller if you need a gear belt. If both of these are flat you need a rubber belt.
You can go to sears.com and find the belt you need with the vacuums model number.
4/27/2010 3:35:47 PM • Kenmore 22812... • Answered on Apr 27, 2010
Need plug c45ecue
i went to sears web site and ordered cover # 8191782. (i don't know whybthey callmit a cover.)
1/12/2010 12:27:12 PM • Kenmore 22812... • Answered on Jan 12, 2010
I need to replace the belt. how do i do it
buy a manuel
11/29/2009 9:32:31 PM • Kenmore 22812... • Answered on Nov 29, 2009
What belt do i need for a kenmore canister vac
I'm not familiar with the model number that you posted. But if the picture you posted is the model you have then this is the belt you need
http://vacbelts.xps.convina.com/20-5201-belt.htm
10/17/2009 4:19:57 AM • Kenmore 22812... • Answered on Oct 17, 2009
3answers
Fix ya are morons
Hey ... I dont know about the others, I am just a ordinary guy trying to answer questions which posters post. I try to do the best I can. I try to use life experience and common sense in my answers. Frankly, if you dont like the pictures, dont view them. BTW, this is a free site and you are free to come and you are free to go.
The men and women posting the answers dont select the pictures, I think the pics are selected either by the site or the people asking the questions. In either event, is your expectation really that Fixya has a picture of every device that people ask about? Next you would complain about the color not matching your device! Give me a break!
I have only asked one question here on Fixya ... and I think the site selected the picture ... (My question has never been answered yet, I have supplied more than 500 answers to all types of questions.)
I think most other experts would feel the same
... and what have you done today to make this a better community my friend?????
10/4/2009 9:50:25 PM • Kenmore 22812... • Answered on Oct 04, 2009
Kenmore vacuum- no suction, brush wont turn
Sounds to me like you have a plugged vacuum. Check all the way through.
9/14/2009 3:33:32 AM • Kenmore 22812... • Answered on Sep 14, 2009
No suction
If the motor is running and is not full of dirt, and the hose is not plugged, the canister must be cracked or open somehow.
9/14/2009 3:29:18 AM • Kenmore 22812... • Answered on Sep 14, 2009
Will not turn on
I would start with replacing the cord end. Especially if you have had it for a few years.
9/14/2009 3:27:21 AM • Kenmore 22812... • Answered on Sep 14, 2009
Kenmore 22812 Bagged Canister Vacuum Logo
Popular Tags
58 questions posted
Top Kenmore Vacuums Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Vacuums
  • Kenmore Vacuums
Most Popular Question
kenmore upright vacuum model
  • Vacuums
