20 Most Recent
Sony VAIO VGN-CS110E/W NoteBook Questions & Answers
I have a sony Vaio
I wonder if your 'Front Light' seems any dimmer than what it was?
It can be your
aging power supply is not providing the full voltage your laptop needs?... Let's say your laptop
needs 19.5 Volts (and it DOES), but your supply can only
provide 16 or lower volts? You
may see results like you are getting now...
New supplies are not that expensive (about $14 inc US shipping) and rather spending a lot for diagnostics and waiting a week or so, a new
fresh supply MAY be all you need!
OK... I just found a NEW supply for $8.52 on eBay
for your system and he's a US Shipper too. It's worth a try!
Anthony
Vaio VGN CS110E power supply eBay
12/2/2017 6:35:42 AM •
Sony VAIO...
Answered
on Dec 02, 2017
Is not starting by window vista
Windows Vista is no longer the current operating system supported by Microsoft. Try to upgrade or get a full copy of Windows 7. Windows 7 works a lot better than Windows Vista did. If you have the discs for Windows Vista, then try ot reinstall, but, again, Windows 7 is the current operating system for Microsoft.
4/27/2016 5:22:15 AM •
Sony VAIO...
Answered
on Apr 27, 2016
Describe your VGN-CS110E MODEL IS
You should send it to them, it absolutely sounds like the computer is overheating which would be the cause of a faulty fan. Make sure you back up all of your information prior to sending the computer out, as they won't hesitate to reset the computer back to its factory settings. Continuing to use the computer in its current state could cause more permanent damage to the computer, so back it up and send it out as soon as possible.
3/21/2011 4:38:09 AM •
Sony VAIO...
Answered
on Mar 21, 2011
VERTICLE LINE ON THE SCREEN
When you power up the computer press F8 key 5 to 6 times so you can see safe mode and other menu then enter in "enable vga mode" then go to display property in control panel.Then change screen resolution to 1024*768 then apply you can also change the display from there. You can change desktop background and other display settings from start menu->control panel->display.. Let me know if you need further assistance. Thanks for using FixYa.
8/28/2010 5:13:23 PM •
Sony VAIO...
Answered
on Aug 28, 2010
I can't start any type of media, itunes, window
1. you possibly may have a virus.
download the Windows Essentials from the Microsoft web site and install and scan.
The program is free from Microsoft for Windows XP and Windows 7.
Here is the link:
http://www.microsoft.com/security_essentials/?mkt=en-us
6/21/2010 7:29:19 PM •
Sony VAIO...
Answered
on Jun 21, 2010
My computer prompts me to go on hybernate because
right click on the desktop..go to screen severs ..and there to power savings..in there remove any settings that will get it to sleep and put it never on all the line down ..including on battery mode..and willnot prompt you anymore untill its shuts down from lack of power in battery mode..and will stay on for ever until shut down manually in adapter plugged mode
5/30/2010 3:47:44 AM •
Sony VAIO...
Answered
on May 30, 2010
Why does startup repair keep popping up on my
This is the system error and it comes when the user doesnot shut the comp in proper way.//
it can also come if due to some reason the comp is shut automatically//
to get rid of it try last known good configuration.
shut down the comp// restart and immed start hitting f 8 cont to get the advance boot menu//
select LKGC and once that is done hopefully your computer will boot perfectly//
5/29/2010 8:23:05 AM •
Sony VAIO...
Answered
on May 29, 2010
Can not get a network connections.
Check if your network settings is configured properly.
Try to see if you have configured a working IPAddress and check your workgroup if you are in a network.
Go to MSDOS prompt
Use ipconfig /all - check your ipaddress
Type ping www.yahoo.com - check if its receives the reply data's 100%
Thanks. Cheers!
4/21/2010 5:01:08 PM •
Sony VAIO...
Answered
on Apr 21, 2010
Motion eye problem
Replace the Cameras Wire Harness, or the Camera itself. You can obtain the parts from Sony
4/14/2010 12:09:50 AM •
Sony VAIO...
Answered
on Apr 14, 2010
My laptop keeps making crackling sounds for a
Cracking sound means either your HDD is going to die or lost of dust on ur FAN.
if sound comes out from Fan side then you can blew dust out using air compressor cane for more over if you are handy on computer then just remove keyboard and blow away all dust (But this is not recommended if you are not well aware of taking parts apart).
If its from HDD (Hard disk Drive) then its time for replacement.
but my guess goes to Fan once its freezes up frequently so Fan needs to be cleaned.
Try from outside blowing up dust if problem still remains then fan needs to be taken out which only Tech can do if you are not familiar with it.
Please post back comments on it.
thank you,
3/20/2010 4:59:26 AM •
Sony VAIO...
Answered
on Mar 20, 2010
I have a problem with cooling fan in my laptop
Hi
Thank you for your query
If you are not a qualified laptop engineer, i would not recommned that you try to replace the heat sink (fan) yourslef, you will literally need to take the whole laptop apart
Please book the laptop into a reputable PC shop or laptop engineer to replace for you
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
2/17/2010 10:11:33 AM •
Sony VAIO...
Answered
on Feb 17, 2010
