20 Most Recent
Lenovo IdeaPad S10-1208U Netbook Questions & Answers
How do I attach a printer to an IdeaPad S10-2 Netbook.
If you have setup disk that came with printer insert disk and go to my computer and select the disk and run the setup It will then install the required drivers, If you do not have the disk drivers can be obtained from the HP website free of charge.
Hi there, I need your help please. I have a new
Nero 7 has an application called Nero play time. Check that out. I have an old copy that has been superceeded by windows 7 ultimate so you can have my key if you like the software. As I am not permitted to provide you with my e-mail you will have to provide me with yours. I will be back ionline tomorrow and will check in with you again ;)
Hope this helps, Please rate and thanks for using Fixya
No sound are my computer
Hi as_shah, if you have no sound on the pc , check the drivers on the pc.
go to device manager by clicking start > right click computer and click Manage > then click device manager
click the arrow under sound > then right click the device and hit uninstall
try to download this link on lenovo website:
http://consumersupport.lenovo.com/us/en/driversdownloads/drivers.html
select the brand if it is notebook and click the model number and continue.
Then download the appropriate driver which is suitable on the operating system.
Run the program , restart the pc and check if it works
Keys are not working correctly on key pad
It may be that you have NumLock on - these function represents a KeyPad on the Letter Keys - usually the U,I,O,P,[,J,K,L,;,M kEYS are replaced with numbers - to switch on/off you should have a key with Number Lock on it possibly abbreviated to NumLck or NumLK etc - activate that Key - may need to use in combination with the FN key as well to toggle the Number Lock on and off - also often a light appears to show its ON
How do i turn my camera power on
try pressing fn+esc to enable to camera. If this doesn't work go to control panel by click start then select control panel and click on device manager. Once you're in device manager, look for imaging devices and click on the arrow/plus sign beside imaging devices. Once you see the camera driver, highlight it and press the delete button on your keyboard to uninstall the driver. After that restart your computer.
If this doesn't work, you may update the drivers for your camera at
http://consumersupport.lenovo.com/en/driversdownloads/drivers.html
Touchpad tapping is not working
You need to download and re-install touchpad drivers to get the tapping function working.
You can download the touchpad drivers from the link below:
http://blogntech.com/download-lenovo-ideapad-s10-xp-driver.html
Bluetooth problem
It will only work if you reinstall windows with the same discs that came with the laptop as it has the right drivers...
HOW TO EJECT A DISC IN LENOVO IDEAPAD 330
The CD/DVD drive may be opened by pressing a button on the drive itself. If the drive does not open by pressing a button on the drive itself, or the button is not available on the drive, Windows natively provides the ability to eject the tray with simple methods that can be performed in the File Explorer. The steps vary from different operating systems:
Note:
- Not all systems come with a CD-ROM, CD-RW, or DVD drive installed internally to the computer
- To verify that, you can check the left and right side of your machine. See if there is any slot to insert your CD/DVD. Normally, there is a button to eject the CD or DVD tray for you to insert a disc
- Another method to identify this is as below:
1. Click Start and type Device Manager in the search box. Select Device Manager
2. In Device Manager look for DVD/CD -ROM Drives
If you don"t see DVD/CD -ROM Drives this means your device has no optical drive hardware. An external optical drive will need to be purchased to run CD/DVD. It is also wise to check your product specification to see if your device has an optical drive.
If you were previously able to play CD/DVD and DVD/CD -ROM Drives has disappeared from device manager or your device is not reading the disc please follow > Your CD or DVD drive is not recognized by Windows or other programs.
- The format capabilities of the drive are listed on the label on the external cover of the drive
- The CD-ROM, CD-RW, or DVD drive can be opened using the emergency eject hole (Bend away a leg of a paperclip to work with. Insert the paperclip slowly until there is resistance, then gently push until the drive door is opened) Applicable Brands
Solution
·Windows 10
·Windows 7 Eject disk tray with File Explorer
- Turn off all applications currently using the drive. Otherwise Windows will prevent you from ejecting the DVD tray
- Hold Windows + E on the keyboard to open File Explorer
- Click the DVD drive icon and click the "Eject" button on the toolbar or right-click on the optical drive and choose Eject from the menu that pops up or down.
Win 10 lenvo ideapad 320 will not play mygames now
really why not ask the game maker directly for help with your w10.
here they are right>?
https://www.mygames.com/
so what do THEY say , it is there code, running.
does Tetris fail or just your games, unnamed,
this maker is bad company they take over your PC
why run this crappp? it takes over your browser,
and more,
and is bad.
the do not even have minimum system requirement there.
nor support. avoid like the Plague.
