20 Most Recent
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Questions & Answers
My extension tubes were put
Hello There!
I had the same exact problem.
Seems something was wrong or stuck in the tubes.
Finally, when I kept trying to clean it out, the tube ripped off and I found a clog of dust in it.
So, try getting replacement tubes & it'll work for sure!
I wish I helped you!
Let me know if you need anymore help!
Don't forget to rate! :)
I own a Kenmore vacuum
If unit beater has stopped working it is either the motor, the power connection to beater or the belt that powers the roller. Which is it?
See if you can download the manual from the mfg or google for it.
Get the belt to turn in Progressive Whisper belt
Make sure the roller is not jamed with carpet threds , remove bottom cover and clean dust balls and obstructions out see if ti resolves problem make sure it's unplugged when checking and install complete before applying power!
Kenmore canister power head not working?
Without more info, I would investigate the drive belt, make sure the beater bar is free to spin (no hair or carpet fibers twisted onto the moving parts), and then check that the power is getting to the motor of the power head. Most often it is hair/fibers that collect around the ends of the beater bar. This causes the belt to stall, heat up and stretch due to the drive motor shaft spinning on one spot because the belt can't move. After removing twisted hair/fibers, you probably only need to replace the belt.
How to replace pcb assembly Kenmore model 116.25513506
1)see your instruction manual, and follow the steps download your i.manual from www.fitness.manualsonline.com or www. retrevo.com2) You must unplugged the power cord, and dissasembley according with your instr.manual.3) use wrist attached with ground, for to avoid E.Discharge.God bless you
Kenmore progressive upright vacuum. It
Hello, gmI
was trying to help you out here. Maybe this will help some? I was going
back to some customers that asked questions in the recent past and even
farther back. It appeared that no one answered some of them, So, I
thought I would take some of my own personal time to see
if I can help. Even though this a Informational site may not have your
exact model or brand, But this site will help you a lot. Here is the
site link about everything you want to know about vacuum cleaners and
possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/vacuum-cleaner.htmPlease
if this helped you at all, if you can find the time and in your heart
to rate my help and some kind words written would be appreciated for my
free help, I would appreciate it. Like I said I
just tried to help, If anything this is good information for future
problems. If you felt that my free help was a waist of time for you, I'm
sorry.I do not get paid to help people on the site, I do it cause I like to help.Here
is also my direct link to my own pages of other areas of my expertise
for other problems you might have in Automotive, Appliance, and
Electronics. Drop In anytime for my help.Thanks, Mikehttp://beta.fixya.com/users/mc1bean
Where is the exhaust to
There is none - the air is blown out thru a microfilter held in place by a removable grille at the back.
I have a kenmore progressive vacuum with a belt
A lot of times the reset button is tripping because there is a problem. The problem could be with the brush roller in this case. A lot of times I see this unit for repair and the end of the brush is so compacted with hair and debris that it has also started to melt. This will also "fool" the reset and trip off. If you are near a service depot try there, or try sears parts if you need to have the brush roller replaced.
Bypassing the reset button is not advisable on any machine.
The nozzle housing has cracked at one end of the
contact Parts direct at sears, when you have them on the phone ask them to e-mail you the sheet that shows how that part is assembled,, you can get the part from them, heres the number
1-800-252-1698
