20 Most Recent HP Pavilion dv4-1120us Notebook Questions & Answers
Hi,problem is this If battery is in the laptop
dv4-1120us Notebook BATTERY 101 if it runs with no battery , then its ok. see? (does not prove internal charging chip is ok, see?) but PC is ok on A/C line so use it. in A/C power. learn too that letting any battery die flat , can kill it.! best is to not walk away from any LT , running on battery only. or risk damaging it. (the laptop tries hard to not do that but is not perfect science ,yet) read up on cell reversal.. never flat line it on purpose and win !!! next learn that batteries are short lived.. last a few years others months, that is what batteries do. even car batteries can fail fast. (ask and old guy that) all batteries are what I call "weak technology" "fails fast" or imported from china, and are junk,. many are. so.... I always have 2 batteries, that way , having 2 good batteries if one dies, its totally obvious, no? whats UP? i have 2 batteries, too, so when on vacation, I dont go dry, see? On some longer trips i carry 3, that is what laptops do best. run with no AC jacks about.
5/14/2017 1:47:22 PM • HP Pavilion... • Answered on May 14, 2017
Caps lock scroll lock flashing continuously
Keyboard problem. Bring it back where you bought it.
5/18/2016 9:23:59 PM • HP Pavilion... • Answered on May 18, 2016
Why won't a samsung 1.5tb connect to dv4
is the samsung 1.5tb an external hard drive? if it is then make sure all your usb ports are working by pluging your external drive to the various ports. if it still does not connect then try updating the drivers using a driver pack solution. if that does not solve it then take your laptop to sservice center to fix it.
11/28/2014 11:16:02 AM • HP Pavilion... • Answered on Nov 28, 2014
Certain keys on my hp pavilion don't work
Blow the keyboad with air blower. try to reinstall all drivers and if not. you have to attached external keyboad temporarily while fixing the issue.
12/22/2012 10:09:50 AM • HP Pavilion... • Answered on Dec 22, 2012
0answers
How i can change the
you need download and install spanish language pack , then from control panel - regional and language setting.
6/8/2011 4:15:29 AM • HP Pavilion... • Answered on Jun 08, 2011
2answers
Hallo how to safe mode
Hi kemisha, to get to the "Safe Mode" program.
You have to "retstart the computer."
Once you "hear to computer - Hard Drive {Hum}, and the "Fan" spinning!"
"This is the (Time you want to 'press the F8 button) several times quickly.
"It is important to do this before the "Prompt Screen" show up.
The {Prompt Screen} gives you the 'option' to go to the BIOS / CMOS setup.
The 'message at the bottom of the screen will read:
Press F2... or Press F12... for?
"Press the [F8] before this 'screen' appear!"
If you do this; the "window below will be 'present."
"Use the {Arrow Keys} to move, and "hightlight" the [Advance Options].
Once you have selected the "Safe Mode" option; press the "Enter" tab.
Now, the computer will "Boot into Safe Mode!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
3/18/2011 1:33:48 AM • HP Pavilion... • Answered on Mar 18, 2011
2answers
Recently, I noticed that my
it sounds like the battery has become faulty to test this repeat the process without the battery in at all and if you get the same result you know its the battery.
To fix this you will have to buy another battery
3/10/2011 3:43:03 PM • HP Pavilion... • Answered on Mar 10, 2011
BIOS BROKEN ON MY PAVILION DV4. IVE TRIED TO PUT A
Check out this article to fix your BIOS...
http://www.hardwaresecrets.com/article/41
3/2/2011 8:29:09 PM • HP Pavilion... • Answered on Mar 02, 2011
H.P Pavilion dv4 1120US will turn its self off as
your battery inside lap top went bad replace battery its the size of a watch battery.
2/27/2011 4:02:02 PM • HP Pavilion... • Answered on Feb 27, 2011
I have d4. I
press together the keys "fn" and "NumLlk"..
2/19/2011 4:07:54 AM • HP Pavilion... • Answered on Feb 19, 2011
I forgot my hp dv4
The password exists to protect you, should a thief gain physical access to your notebook.
So, find the original sales-receipt, to prove that you are the owner, and telephone HP Support, and get assistance from them in changing the password.
1/28/2011 11:38:03 AM • HP Pavilion... • Answered on Jan 28, 2011
HP Pavillion dv4 turn on and the fan start for a
Hello, that sounds a motherboard problem...
Try to do this first :
1- take the battery out and disconnect from power
2- press and hold the power button at least 10 seconds
then put only the power cable not the battery and try to boot...
If this dont help...your motherboard needs to be repaired or replaced.
Thanks.Please rate this answer
1/25/2011 1:21:55 PM • HP Pavilion... • Answered on Jan 25, 2011
I need to get the motherboard of my HP pav.
Always use an authorised HP service centre for a job like that otherwise you may finish up with problems like incorrect mother board ownership/serial numbers. Only HP can reset and sort that out for you.
Avoid getting only half a job done!
1/7/2011 10:53:56 AM • HP Pavilion... • Answered on Jan 07, 2011
My motherboard of my HP
Consult an authorised HP service centre to avoid after repair problems!
There are none on ebay at present.
1/7/2011 10:42:05 AM • HP Pavilion... • Answered on Jan 07, 2011
2answers
I use to be able
Get a Coolant for your Laptop..
its need Air or air conditioner to make it cool
12/21/2010 2:48:24 PM • HP Pavilion... • Answered on Dec 21, 2010
Dim LCD screen
Please refer to the following article for a detailed diagnosis of the problem:
http://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
12/8/2010 7:14:56 PM • HP Pavilion... • Answered on Dec 08, 2010
My HP dv4 1120us laptop
Sounds light a power switch short, but lets try to take the memory out of the laptop and power on the laptop. Does it boot up? if so lets try 1 memory stick at a time.
11/30/2010 10:13:12 PM • HP Pavilion... • Answered on Nov 30, 2010
Hello, I have a problem with
It may be caused by overheating. Overheating is the main problem with HP portables. Use a fan to cool down the computer and check how long it last working. If blowing air with a fan "Appears to fix the problem" stop using the computer and get maintenance service for it. The processor area needs to be cleaned.
11/23/2010 9:23:49 PM • HP Pavilion... • Answered on Nov 23, 2010
HP Pavilion dv4-1120us Notebook Logo
36 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
bios broken pavilion dv4 ive tried put
  • Computers & Internet
