20 Most Recent HP Compaq Presario CQ50-210US Notebook Questions & Answers
5answers
How to install microphone in laptop?
when the times we chat in yahoomessenger,my auntie call me she did not hear any sound from my laptop,,so haow to install microphone?
5/7/2021 11:50:51 AM • HP Compaq... • Answered on May 07, 2021
Compaq Presario Cq57-210US - Online Vide Lag
Make sure you have the latest version of flash player installed. What browser are you using? If it's chrome, make sure there aren't multiple versions of flash player enabled by opening a new tab and going to chrome://plugins. Are you having trouble with local video (on the machine itself) as well? If so, you may need to update your graphics drivers. If none of the above are helpful, try downloading and installing the latest version of the k-lite codec pack
7/14/2013 3:32:12 PM • HP Compaq... • Answered on Jul 14, 2013
Spots lcd
Run the software diagnostic, for to get the result , or download the software from your hp. go to www8.hp.com and donwload. God bless you
7/6/2013 7:27:45 PM • HP Compaq... • Answered on Jul 06, 2013
How can i get back my microphone on my HP COMPAQ Presario CQ50-210US Notebook
Where is your microphone gone :) ? Reinstall audio drivers !
4/17/2013 9:31:39 AM • HP Compaq... • Answered on Apr 17, 2013
My screen is black
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode, if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power. Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness. Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over. Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop. Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
1/20/2013 1:38:41 AM • HP Compaq... • Answered on Jan 20, 2013
Which software can i get for my windows 7 hp presario cq56 amd laptop that has a female voice welcoming me at startup and shutdown?
Just do a google search. You can also download your own female voice.
5/25/2012 7:51:13 PM • HP Compaq... • Answered on May 25, 2012
2answers
VGA DRIVER
i need vga drivers for hp amd athalon 64
5/17/2012 2:47:07 AM • HP Compaq... • Answered on May 17, 2012
I used to have microphone access on my gateway lap
Can you do a scandisk for missing files?
3/27/2012 11:55:00 AM • HP Compaq... • Answered on Mar 27, 2012
I have a 2-year old
Check to see if your hdd failed, by replacement?
2/1/2012 9:58:48 AM • HP Compaq... • Answered on Feb 01, 2012
Hi,i have a compact celeron,thisese
Check mixer for mic input setting?Scandisk for any missing files?
2/1/2012 9:54:30 AM • HP Compaq... • Answered on Feb 01, 2012
My laptap missing mic driver
Check your mixer settings for mute or low volume.Check your mic input for proper connection, or contact resistance.
2/1/2012 9:49:04 AM • HP Compaq... • Answered on Feb 01, 2012
My notebook does not come notebook on any more why?
It maybe Athlon X2 shorted out. Replace the cpu so that it will not shut down the charger.
1/30/2012 12:44:44 PM • HP Compaq... • Answered on Jan 30, 2012
Missing coprocessor driver
My friend i would say the update package you used was incomplete.seen some similar problems try to get use system restor to restor back vista then use another update package and retry the process.does this wor,
1/30/2012 12:15:08 PM • HP Compaq... • Answered on Jan 30, 2012
Mic is not working
if your opreating system windows7 please check driver and micro phone settings
check mic jack
please vote me and rate it
8/31/2011 1:07:53 PM • HP Compaq... • Answered on Aug 31, 2011
Compaq Presario CQ50-210US Graphics Driver
http://www.nvidia.co.uk/Download/index.aspx?lang=en-uk
5/18/2011 7:21:48 PM • HP Compaq... • Answered on May 18, 2011
I need drivers
All drivers and information for your laptop can be found at HP's site.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3795234&
If this was helpful, plase rate it high. thanks
5/18/2011 1:59:34 PM • HP Compaq... • Answered on May 18, 2011
3answers
Laptop overheating and shutting down
Laptop heatup is mainly due the clogged heat sink and fan etc, which requires to be cleaned. Laptop shuts dwon automatically when reaches the temperature limit to prevent damage. It is strongly recommended that you clean the heat sink etc yourself or seek help from authorized professional at the earliest to avoid any damages to the PC.
If you are familiar with working inside such electronics, then you can do it yourself after studying the following useful links about CQ-50 Disassembly. On the contrary, if you dont have sufficient experience/ idea about opening/ repairing laptops, DONT try it and get assistance from a professional,
Dissassembly CQ-50
Maintenance & Service Guide CQ-50
Hope it helps! Do convey your feedback
CreativeTECH
5/14/2011 12:24:46 AM • HP Compaq... • Answered on May 14, 2011
Sir i need the windows xp sp2 driver.compaq
3/9/2011 11:30:16 AM • HP Compaq... • Answered on Mar 09, 2011
HP Compaq Presario CQ50-210US Notebook Logo
94 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
vga driver
  • Computers & Internet
