20 Most Recent
Acer TravelMate 5720-6635 Notebook Questions & Answers
Error message of "Unable to detect fingerprint device"
Go to control panel from start menu,then click icon "add hardware".
Follow the instructions, click yes when asked about device is connected,then choose something like"human interface device", keep following the procedure until you find the hardware that match with windows.
Hope it works!!!
Sir,,i hav an acer TM5720
Go into the device manager and remove the camera. Then scan for hardware changes. It will find the camera and load the required drivers. If, for some reason, it finds the camera but not the drivers, go to the Acer webpage for your laptop and download the drivers. When you install them, just point to that file.
Semper Fi,
Z
Recover webpage
Try checking your browsers add on settings. Disable flash and see if it works, maybe flash is corrupt. If this helps, remove the addon malfunctioning and reinstall it. Also update your browser to latest version.
OS
usually OS or O/S stands for 'Operating System'
This some software - a collection of programs - that enable you operate your computer. For example they tell the computer how to interpret the use of keyboard and mouse, and how to send images to the screen or visual display unit (VDU). Read in more detail here
http://en.wikipedia.org/wiki/Operating_system
21.April.2014
My wireless adaptor isn't working
This model does have wireless. I had a similar problem a little while ago, I plugged the unit in to a wired connection, and on it's own, disabled the wireless adapter.
Go to start--> control panel--system-->hardware-->device manager
look under the "network adapters", there should be a wireless adapter or 802g something something, right click on this item and click "enable".
You should then be able to browse for wireless networks now.
Travelmate 5720 problem
Turn off computer, remove battery, press power button for 30 sec.Re-install battery and try a fresh start. good luck
I have to change my charger jack of my travelmate
THE BACK HAS SCREWS AS WELL AS SELF NOTCH ALL AROUND THE SIDES. ITS A BIT TRICKY AND DELICATE AS WELL. YOU HAVE TO INSERT A SMALL SCREW DRIVER IN BETWEEN THE PANEL TO OPEN THE BOTTOM .IF YOU HAVE NO IDEA OF IT ITS BETTER LEFT TO A PRO. TO AVOID DAMAGE.
REGARDS.
PLZ RATE MY SUGGESTION.
After installing drivers for Acer
HI there,
it seems that you don't have the drivers installed for the webcam please download the drivers from the links below
For Windows xp (32 bit)
Bison
Suyin
For Windows Vista (32 bit)
Bison
Suyin
Do post us if you find any problem while installing
Regards,
Bilal
