20 Most Recent Kenmore 53542 / 53544 Side by Side Refrigerator Questions & Answers
2answers
What is the cu. ft. of model 52552100, serial
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
3/19/2015 5:29:49 AM • Kenmore 53542 /... • Answered on Mar 19, 2015
What's your problem?glow in freezer of kenmore side by side
During the Defrost cycle, the Heating located behind the back panel in the freezer is engaged...... and is Normal.. It's one the method's used to melt the build up of Ice that has developed, keeping the foods nice and cold. You may also experience hearing the same sound you get, if you went to Iron clothes and test the Iron to see if it's hot.
11/29/2013 1:18:14 PM • Kenmore 53542 /... • Answered on Nov 29, 2013
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
11/28/2013 3:42:00 AM • Kenmore 53542 /... • Answered on Nov 28, 2013
Refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
7/3/2013 10:30:07 PM • Kenmore 53542 /... • Answered on Jul 03, 2013
0answers
What size is this fridge?
there is a sticker some where inside that will tell you cubic feet
10/7/2012 9:22:01 AM • Kenmore 53542 /... • Answered on Oct 07, 2012
5answers
Fridge not cooling
fridge not cooling
5/2/2012 7:36:03 AM • Kenmore 53542 /... • Answered on May 02, 2012
The evaporator coil is frozen.
If the entire coil is frozen you can defrost it and it will work for 2-3 days but eventually you will be back at square one. You have a defrost problem and you should replace what is broken. I don't know what you have but it could be the heater, terminator, defrost timer or board, and thermister.
12/30/2011 2:07:15 PM • Kenmore 53542 /... • Answered on Dec 30, 2011
Water flowing to the icemaker would not stop. It over flowed the
sounds like the water switch is stuckopen or the valve is. Is the water going to the icemaker or thru the door. If the icemaker is overflowing and doesnt shut off then unplug unit,still coming in change the valve. Not coming in then look at the switch.
12/30/2011 4:11:24 AM • Kenmore 53542 /... • Answered on Dec 30, 2011
I have an amana S/S
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
8/5/2011 9:41:38 PM • Kenmore 53542 /... • Answered on Aug 05, 2011
0answers
Ello im looking for a
Take your old one with you to an appliance parts supply house. They will be able to match you exactly, or provide a compatible model. Shouldn't be a problem at all.
Regards, --W/D--
1/14/2011 12:03:52 AM • Kenmore 53542 /... • Answered on Jan 14, 2011
Between the doors is getting very hot
Pull the refrig out and remove the lower panel . Is the fan working ? If so , then the coils need cleaned . If not , check for something obstructing the fan blade . If nothing , and the fan motor not working , replace the fan motor .
11/15/2010 2:03:55 PM • Kenmore 53542 /... • Answered on Nov 15, 2010
Ice maker just stopped making ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
11/7/2010 11:17:21 PM • Kenmore 53542 /... • Answered on Nov 07, 2010
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
125 questions posted
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
maytag refrigerator sidebyside ice maker
  • Refrigerators
