remove tray, ice may be frozen around auger or gear that spins auger, dump all ice and start over making ice. also, wile tray is out hi dispense switch and see if grer spiindle rotates, if not ur motor has gone bad
95% of ice maker problems are the motor module. See http://tinyurl.com/ykln8r for what it is and if it matches your fridge. Basically here's what ya need for ice... 17 degrees (F) or below, water fill solenoid working with water flow, t-stat on ice tray working OK and motor module turning.
thanks for the question looks like the ice maker does not cycle there is a electric motor that turns on to drop the ice seems like that doesnt work looks like you need a new ice maker Thanks for the questiuo The appliance doc
Some tubes turn brown gradually with age. This is normal. But if yours is not made of that material (not sure what its called), then it could be that the pipe is dirty. If this be the case, it is definitely better to get the line replaced, as it is definitely a health concern. I would recommend getting a filter fitted to the line as well, just as a precaution..
Thanks for the question There is a water valve just for the ice maker so the problem could be there if you have a volt meter you can check the valve what you can do to check the valve reverse the wires onthe valve and push your water dispenser if no water goes into your ice maker . you have a bad valve replace thanks for the question The appliance doc
Coldspot 106. Model
This model refrigerator is a relatively small refrigerator. It is a Freezer on top model, and Sears documents lists this unit at 18.1 cu ft. I hope that answers your question about capacity.
I'm glad I could help. If you need anything else, just let me know.
In reality, when you buy a replacement, you buy by dimensions to fit the space not cubic feet of the old one. Go to Home Depot armed with a tape measure.
Turn it off by removing the wall plug for 10 minutes. This will do a power rest to the control electronics. This is a bottom mounted freezer, so cold air for the fridge is vented upwards by a fan. Make sure it is running and there are no ice blockages. Strangely they call the fan in the fridge an
Refrigerator Evaporator Fan Motor. The part is obsolete anyway.
If it normally says 4 for the fridge, that would be 4 degrees Centigrade, which means the freezer should show minus 18'C. Or 36'F Fridge / 0' F Freezer/
This shows all the parts.
https://www.searspartsdirect.com/model/3tradtge4f-000582/kenmore-79575004401-bottom-mount-refrigerator-parts
