20 Most Recent
Invicta Speedway 9223 Wrist Watch Questions & Answers
Hi there, I have recenlty purchased the Invicta
If you have pressed the 2:00 push button, and the chronograph hand has not started, the movement is defective.
You should return the timepiece directly to the seller in exchange for another. If they are an authorized dealer, you may return it directly to Invicta with your warranty, and they will provide the repair / replacement directly.
Again, there is nothing that you are doing wrong, the movement itself is defective. We see this in a small percentage of watches, but often enough. Do not take no for an answer from the seller if you have just purchased this defective item, especially if they are not an authorized reseller / dealer of this brand.
My invicta stainless steel band has two bent
Most watch pins go for an average of 5 to 10 dollars per pin. If the band is in good condition there is no need to replace it. Most invicta metal bands can retail from 35 dollars and up. We are located in the Holyoke Mall in Holyoke MA
Invicta Speedway 9223 not keeping time
It sounds to me as it is a quartz chronograph and it is right that the centre seconds hand moves only if the pushbutton is pressed. If you look close enough, you will notice that the small subdial finger is ticking and counting seconds. It is recommended to replace battery, as sometimes watches been laying in stores for a few years before selling and the battery is flat or underpowered.
Want to know more about your watch? Go to
www.invictawatches.com and find out.
Regards
Arthur
My Invicta reserve speedway won't keep time but the stop watch works need help
If the stopwatch is working but the timekeeping is not accurate on your Invicta Reserve Speedway watch, there could be several possible causes for the issue. Here are some steps you can take to troubleshoot the problem:
- Check the battery: A weak or dying battery can cause timekeeping issues. Try replacing the battery with a fresh one to see if it helps.
- Check the movement: If the battery replacement doesn't solve the issue, the movement (the internal mechanism that powers the watch) may be damaged or worn out. A professional watchmaker can diagnose the problem and repair or replace the movement if necessary.
- Check the setting: Make sure the watch is set to the correct time and time zone. You can refer to the manual or instructions for your watch on how to set the time and time zone.
- Magnetization: Sometimes, exposure to magnetic fields can interfere with the timekeeping of a watch. If you suspect that your watch has been exposed to a strong magnetic field, take it to a professional watchmaker for demagnetization.
- Water damage: If your watch has been exposed to water or moisture, it can cause damage to the movement and affect the timekeeping. You can try drying out the watch and replacing the battery, but it may require professional repair.
If none of these steps resolve the issue, you may need to take your Invicta Reserve Speedway watch to a professional watchmaker for diagnosis and repair.
What size battery for my invicta model 10404
The SR721SW silver oxide coin cell and 370 / 371 batteries will be the batteries. Unless stated otherwise on the Invicta website or by an authorized retail official, do not look for other batteries.
Watch Battery for Invicta 11879?
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Posted by ADMIN... on Dec 31, 2018
What size battery invicta model no 6370?
