20 Most Recent Kenmore 44103 Side by Side Refrigerator Questions & Answers
Panel between fridge and freezer extremely hot
this is happening because company used pipes inside refrigerator body, as you mentioned now its heating more than normal,. need some technician to check if there any blockage etc. otherwise less heating of body is normal.
11/30/2017 10:26:22 PM • Kenmore 44103... • Answered on Nov 30, 2017
I have an Amanda Side
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/25/2011 10:29:54 PM • Kenmore 44103... • Answered on Aug 25, 2011
I have a Kenmore side
Sounds like the dual water inlet valve on the back where the water supply is connected, has gone bad and is leaking across to the other side. It may also put water into the ice maker when you use your dispenser.
1/13/2011 8:39:45 PM • Kenmore 44103... • Answered on Jan 13, 2011
Freezing on the cool side.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
12/14/2010 4:04:28 AM • Kenmore 44103... • Answered on Dec 14, 2010
Need info for a kenmore side by side refrigerator
Good day,
With that amount of info it would be hard to try to pinpoint it. Here's a list of items that can cause a refrigerator to not cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see it could be one of many,many items. If your handy with a meter you might want to start at the bottom back of the machine where the compressor is located.
Sounds as if it is not running, or running without refrigerant in the system.
Also, if it has a cooling fan motor in that area, make sure it runs, since all fan motors are wired to run at the same time.
10/15/2010 8:28:08 PM • Kenmore 44103... • Answered on Oct 15, 2010
Frt18hb5dw2 Frigidaire, Freezer workes but not Refrigerator.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
9/29/2010 9:57:50 PM • Kenmore 44103... • Answered on Sep 29, 2010
Kenmore Fridge - won't stop making ice
there is a part that you cannot see that has broken off. The on/off bar normally moves another part...this part is broken off. It may have occurred when the ice was full but the bar was restricted by from raising with the ice pile. try prying off the plastic end cover to see the broken part.
9/28/2010 12:01:31 AM • Kenmore 44103... • Answered on Sep 28, 2010
8answers
Water dispenser
this is one heck of a job as you gotta disconnect all the tubes and wiring at the bottom and take off the freezer door.. Check owners manual on how to disassemble door as you would if you only had a 30" door opening on your house. then you need to take off or unscrew many screws to take off the door gasket then the rest should fall into place.
2/1/2010 7:59:52 PM • Kenmore 44103... • Answered on Feb 01, 2010
Kenmore Fridge: 44103 side by side: I keep finding a
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
9/15/2009 11:59:49 PM • Kenmore 44103... • Answered on Sep 15, 2009
2answers
Water appears on floor once a day
see if drain hose is in pan under fridge
8/10/2009 6:13:04 PM • Kenmore 44103... • Answered on Aug 10, 2009
2answers
Kenmore side by side makes no ice
the water line coming into the freezer may be iced up. or the motor that spins the ice "ejector" arm may be stuck. try spinning it manually (just dont force it).
5/29/2009 2:04:12 AM • Kenmore 44103... • Answered on May 29, 2009
Where is the defrost timer for Kenmore 106 48262893
It might be the defroster itslef mine just went bad.
4/9/2009 6:15:14 PM • Kenmore 44103... • Answered on Apr 09, 2009
Ice Maker Don't Work
Be sure the valve works befor it is installed. Very common mistake.
4/9/2009 6:05:06 PM • Kenmore 44103... • Answered on Apr 09, 2009
My kenmore side by side
replace the white hose.
4/9/2009 4:16:27 PM • Kenmore 44103... • Answered on Apr 09, 2009
Water drips on floor under the door.
Take off the lower part on the back. Follow the water line up the back. It is connected in two spots lowere rear and upper rear going into freezer.
4/9/2009 4:15:16 PM • Kenmore 44103... • Answered on Apr 09, 2009
Fridge not working but freezer does
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
3/30/2009 11:37:07 PM • Kenmore 44103... • Answered on Mar 30, 2009
Kenmore side by side refrigerator wont make or dump ice in holding container
Ice maker will not make ice. just acts like it is frozen up or something like that
3/5/2009 5:16:08 PM • Kenmore 44103... • Answered on Mar 05, 2009
Icebuildup on rear wall of frig , caked up ice on the freezer flo
This is possibly your thermostat which needs to be replaced. Make sure that the fanmotor in the cabinet is working and you have airflow. If no airflow this could also indicate that the defrost system is faulty.
3/5/2009 1:57:01 PM • Kenmore 44103... • Answered on Mar 05, 2009
Kenmore 44103 Side by Side Refrigerator Logo
49 questions posted
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
water dispenser
  • Refrigerators
