20 Most Recent Jaeger-lecoultre Compressor 1728470 Wrist Watch Questions & Answers
You'll notice that the band, between the 2 fingers of the watch, is held by a pin. That pin has a very small head, like a nail. With a very small flat screwdriver, (jeweler type), simply get between the finger of the watch and the head of the pin and slowly try to disengage the pin. Push it to the other finger. (be careful as to NOT drop the pin as they are spring loaded
Jaeger-lecoultre... | Answered on Dec 18, 2010
Do you have the model number. That would help you to make some speculations or comparing the recent cost or repair.
Thanks!!
Jaeger-lecoultre... | Answered on Sep 19, 2010
It might be worth having the back of the watch removed to see if there is anything engraved on the movement.
You might find that cleaning the watch gets is going, although the advice of the watch repairer should be asked for on this, as it might be very worn and in need of new parts which are unlikely to be available.
If it works and there is information on the movement, you might be able to get some information on the watch from the maker. Visit their web site (www.jaeger-lecoultre.com/) and make an inquiry, giving them all the information that you have.
An interesting problem!
Good luck.
Jaeger-lecoultre... | Answered on Jan 24, 2010
If you can provide over here the picture of the watch, that would be easy to identify the problem and fix.
Let me know
Jaeger-lecoultre... | Answered on Sep 08, 2009
What is this?
Watches | Answered 22 hours ago
Take the watch to a jeweler to determine battery type.
Watches | Answered 2 days ago
"G-Shock WR20BAR" could mean hundreds of different G-Shock models. If yours is an all digital G-Shock, the answer is fairly simple. When looking at the watch face, the upper left corner button is the "ADJUST" button. Press and hold the ADJUST button for a couple of seconds. You should start to see something flash on the display. Some models will have many options to select in ADJUST mode. To scroll through them, press the MODE button, which is in the lower left corner. You set the hour, minute, seconds, month, date, and year each separately. When you are done, press the ADJUST button again and you'll be back to normal time keeping.
If you want to learn more about your G-Shock, there is something called a "MODULE" inside it that is the brains of the watch. You can find that on the back of the watch, outlined in a rectangle. Usually a 4 digit number. You can download the manual for your watch using that number, if you enter it on a CASIO website:
http://support.casio.com/en/manual/manuallist.php?cid=009
Fixya does not sell watch batteries.
Watches | Answered 3 days ago
Did you buy it on eBay? If you did, it is a fake made in China. The battery is probably flat.
https://www.ebay.com/p/Womens-Liz-Claiborne-Analog-Dress-Watch-Bracelet-Set-LC9043-Rose-Gold-HP/15008578708
Watches | Answered on Apr 17, 2019
Is breiting j44362 even a real serial number
SORRY NO IDEA AS I DID NOT REMOVE THE OLD ONE
Jaeger-lecoultre Compressor 1728470 Wrist Watch Logo
1 questions posted
Top Jaeger-lecoultre Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Jaeger-lecoultre Watch Expert? Answer questions, earn points and help others
View Most Popular
  • Jaeger-lecoultre Watches
Most Popular Question
replace watch bands thank
  • Watches
