20 Most Recent
AKG Perception 100 Microphone Questions & Answers
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo.
Maybe you need a stereo mini. Usually a cable mismatch is the problem.
Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two.
Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel?
I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Stopped working. occasionally will power up. can't open it.
to open it look where the lead enters the microphone body you will see a circular rebate surrounding the connector, there are two notches opposite each other you will need to buy or make a tool to fit into the rebate and locate into the notches and simply unscrew. do not attempt to unscrew th body as you will damage the microphone..
AKG Perception 100 not working, at all
The problem is that your amp probably doesn't have phantom power. This mic requires phantom power to be supplied to it via the XLR connector. Most mixers and mic pres have that feature, but most guitar amps do not, I believe. Hope that helps...
I have an issue with my AKG wireless were when i turn my headphones on it blinks blue and does not connect to my laptop if anyone could tell me how to fix it that will be great
Posted by Stephen Chiarchiaro on Sep 13, 2019
Hi Lemon Juice gaming, indicate brand, model and type of equipment and the headphones you are commenting on, also through which medium you are connecting the headphones and the computer, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Lemon Juice gaming, indica marca, modelo y tipo de equipo y los auriculares que estas comentando, tambi?n a trav?s de que medio te estas conectando los auriculares y la computadora, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
9/13/2022 5:36:27 AM •
AKG Audio...
Answered
on Sep 13, 2022
