20 Most Recent Kenneth Cole KC3485 Wrist Watch Questions & Answers
Well if its a spring-bar you're looking for you can generally find assorted sets fairly cheap on ebay....if you need a screw pin you could try ebay or possibly a radio-shack? I think I've found smaller screws there before generally used in small electronics.
Kenneth Cole... | Answered on May 06, 2013
This is the most common repair for a watchmaker. A local watchmaker should be able to do this very inexpensively.
Kenneth Cole... | Answered on Aug 20, 2010
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Kenneth Cole... | Answered on Jan 21, 2009
I would possibly try the kennith cole help desk
You will probably have to contact them directly
Kenneth Cole... | Answered on Jan 06, 2009
WE DONT VALUE ANYTHING HERE SORRY
Kenneth Cole... | Answered on Sep 13, 2019
Take the watch to a jeweler for a demonstration.
Kenneth Cole... | Answered on May 13, 2019
Ive heard people say many times to put cell phones in a bowl of dry white rice to remove moisture from them,so Im sure it would work for a watch as well. Just make sure to leave the watch in the rice over night,and make sure to have none of the watch showing in the rice---it will need to pull moisture from within the tiny parts.
Kenneth Cole... | Answered on Feb 18, 2019
Maybe a reset button inside marked a.c. if so short it between battery and a.c. button.
hope this helps
Kenneth Cole... | Answered on Dec 21, 2018
Type, not size. Take your Kenneth Cole watch to a jeweler who will open it and identify type.
Kenneth Cole... | Answered on Nov 19, 2018
Try Googling (Kenneth Cole)(kc8041)(manual) without parens.
Kenneth Cole... | Answered on Mar 17, 2018
Try Googling (Kenneth Cole)(UL 1197 S 60)(manual) without parens.
Kenneth Cole... | Answered on Feb 10, 2018
Kenneth Cole KC3485 Wrist Watch Logo
Popular Tags
6 questions posted
Top Kenneth Cole Watches Experts
Janelle Schoonover
Janelle Schoonover
Gary Nitowski
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
View Most Popular
  • Kenneth Cole Watches
Most Popular Question
shorten watch bracelet
  • Watches
