20 Most Recent Kenmore 64663 Microwave Oven Questions & Answers
3answers
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
4/8/2022 2:36:02 AM • Kenmore 64663... • Answered on Apr 08, 2022
Microwave not working. Burnt smell
time for someone to unplug it and look inside, if something smells like it burnt do not plug in etc.Common failure parts in most microwaves are:Diode most use:12_21_2012_5_42_00_pm.jpgMagnetron which is connected to the inverter most use (circuit board)12_21_2012_5_43_02_pm.jpgAC filter cap which varies in shape some what but can be still tested with a ohm meter, also if really bad will be buldged out on sides or top.12_21_2012_5_44_40_pm.jpg
12/21/2012 5:44:48 PM • Kenmore 64663... • Answered on Dec 21, 2012
My Kenmore 64663 still heats but I don'y hear the fan anymore while heating
If it's the internal cooling fan, you really need to get that repaired before you cook anymore with it. Otherwise, your magnetron will be destroyed.
If it's the hood / exhaust fan, then the problem may be the motor or a problem on the control board.If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't feel confident to tackle it yourself, I would contact Sears for service.
8/25/2008 4:33:31 AM • Kenmore 64663... • Answered on Aug 25, 2008
F-9 code in display
F9 usually indicates a problem with the door switches or a broken door switch mount.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your FULL model number here: http://tinyurl.com/gv383
2/4/2008 4:32:20 AM • Kenmore 64663... • Answered on Feb 04, 2008
Microwave problem
I would first suspect a bad door switch or door switch mount.
If you follow up with your full model number, I can possibly give more precise advice.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
10/15/2007 1:49:34 AM • Kenmore 64663... • Answered on Oct 15, 2007
Kenmore microwave model 721.85033010 works fine except the exhaust fan comes on just out the blue for no reason and wont shut off without unplugging.
It turns itself on
  1. Interlock switch If your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control board If your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
But before throwing parts at it give these folks a call... https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Microwave/74-6-878350-/New/Kenmore-Microwave-Turns-On-By-Itself-721-85033010 Best to you
9/2/2023 9:10:40 PM • Kenmore... • Answered on Sep 02, 2023
Looking for manual for a Kenmore Viking 851.8250800 Microwave.
It looks like it is too old. Nothing in Kenmore or Viking. https://www.google.com/search?q=Kenmore+Viking+851.8250800+manual ..
8/7/2023 7:31:34 PM • Kenmore... • Answered on Aug 07, 2023
Kenmore over the range microwave tripping breaker
You've found the proper location if you're seeking for the fuse for your Kenmore microwave. The fuse is often found in the microwave's or behind the control panel. You must take off the microwave's exterior cover in order to reach it. After you've identified the fuse, you may see if it has blown. If so, you'll have to swap it out for a new one. It might be preferable to seek professional advice if you are unsure on how to proceed.
4/18/2023 8:31:03 PM • Kenmore... • Answered on Apr 18, 2023
2answers
When trying to use convection with Kenmore hood combination it stars then stops and the display says F-5. What does that mean
If you are getting an F-5 error code on your Kenmore hood combination, it typically indicates a problem with the temperature sensor. This error code may occur when you are trying to use the convection feature, as you have described.
To troubleshoot this issue, try the following steps:
Turn off the power to the unit and unplug it from the electrical outlet.
Wait a few minutes, then plug the unit back in and turn on the power.
Try using the convection feature again and see if the error code reappears.
If the error code persists, you may need to replace the temperature sensor. You can consult the user manual for your Kenmore hood combination or contact Kenmore customer service for assistance with this.
If the unit is still under warranty, it's recommended to contact Kenmore customer service for repair or replacement options.
4/5/2023 7:13:24 AM • Kenmore... • Answered on Apr 05, 2023
Need a replacement display board for a Kenmore Microwave Model No. 318279601B
These are all the top suppliers, but that model number is not showing. If the display has gone dim, you can get an electronics technician to replace the capacitor that runs the display. https://www.google.com/search?q=Kenmore+Microwave+318279601B+parts ..
3/11/2023 7:20:22 PM • Kenmore... • Answered on Mar 11, 2023
My Kenmore stove timer started going off every 45 seconds
It sounds like you may be experiencing an issue with your Kenmore stove's timer function. Here are a few steps you can try to resolve this issue:
Check the timer settings to make sure that the correct time and alarm settings have been entered.
Try resetting the timer by turning it off and back on again, or unplugging the stove and waiting a few minutes before plugging it back in.
Make sure that there are no buttons or knobs stuck on the stove, as this could cause the timer to activate repeatedly.
If these steps do not resolve the issue, it may be necessary to contact a professional appliance repair service for further assistance.
2/1/2023 2:26:53 AM • Kenmore... • Answered on Feb 01, 2023
I have a Kenmore over the range microwave oven and it is not powering on after a power outage. What could be causing this please?
Question edited for spelling of Kenmore and typos. Question moved from Kenmore Washing Machines. All about repairing microwave ovens https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
1/22/2023 1:47:03 AM • Kenmore... • Answered on Jan 22, 2023
I need user manual for Godrej 20E 08 SLGX microwave oven
I have a godraj 20E 08 SLGX MICROVIEW OVEN .Can you plz tell me can I bake in this if yes then how i preheat it for baking
1/12/2023 3:13:10 PM • Kenmore... • Answered on Jan 12, 2023
From top to bottom, what should be the types of door interlock switches on a Kenmore microwave 790.803.
Maybe get the part here? https://www.partselect.com/Models/790803/
12/30/2022 6:16:41 PM • Kenmore... • Answered on Dec 30, 2022
Where can I find the specs for a Kenmore oven model # 326B1016P001.
That is the strangest model number for a Kenmore and doesn't follow the normal 3 dot 7 ***.******* format of others. Just measure the front of what you have. They come in standard sizes. https://www.google.com/search?q=kenmore+%22326b1016p001%22+installation+manual ..
12/10/2022 8:00:48 PM • Kenmore... • Answered on Dec 10, 2022
Kenmore microwave model 401.85053010 won't heat or cook anything.
Unfortunately, this is not something that can be diagnosed from a distance, unless you had access to a "Kill-a-Watt" meter or equivalent. It could be caused by a bad door switch, a bad relay on the main board, a bad magnetron, or a bad HV diode. (The HV capacitor is probably OK, because if it were bad [shorted], it would blow fuses.)
10/28/2022 6:00:32 AM • Kenmore... • Answered on Oct 28, 2022
Kenmore Elite Microwave 721.79209010 Open Door and Microwave starts running;
Yes, a bad door interlock switch would cause this; either the top switch or the bottom switch. (The middle switch is called the Monitor switch. If it were bad, you microwave would blow fuses as soon as you press Start.)
10/28/2022 5:57:10 AM • Kenmore... • Answered on Oct 28, 2022
What does an F=1 code mean?
Convector element has failed. Time for a repair.
7/25/2022 5:30:59 PM • Kenmore... • Answered on Jul 25, 2022
Kenmore 64663 Microwave Oven Logo
14 questions posted
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Microwave Ovens
Most Popular Question
microwave not working burnt smell
  • Microwave Ovens
