20 Most Recent
La Crosse EH-21GA Wrist Watch Questions & Answers
I WANT THIS WRIST WATCH NOW
mcdevito75 here, Contact Lacrosse watch, online at Lacrosse watch.com or by phone at 800-380-5056 with your request.
12/14/2022 8:29:57 AM •
La Crosse...
Answered
on Dec 14, 2022
After the battery was replaced the watch is 4
hello,kindly pull out the silver control ironby the right hand side gently,and you will use it to set it by turning it to the actual time you want,either by turning it right or left,then after you have finally done with the setting,you have to press it in back to make sure it keyed in.you can start making use of your wrist watch as normal.
wish you good luck,
take care.
5/13/2010 1:46:47 PM •
La Crosse...
Answered
on May 13, 2010
Hi my xg-55 froze up,
You will need to take this watch in to a local Certified Master Horologist. It will have to be opened and reset from the inside by shorting the appropriate contacts on the movement. It may also require a battery to operate properly, if it has not been replaced in the past 1-2 years.
If you wear this watch in the water, you need to have it pressure tested to ensure its resistance after the procedure. This is properly done with a pressure testing machine that usually is found at Horologist / Watchmaker shops only.
2/4/2011 8:46:40 PM •
La Crosse...
Answered
on Feb 04, 2011
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM •
Watches
Answered
on Apr 07, 2024
