20 Most Recent Kenmore 63662 / 63664 / 63669 Microwave Oven Questions & Answers
Kenmore microwave hood 62643200
What's your question? If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
1/25/2015 7:20:44 AM • Kenmore 63662 /... • Answered on Jan 25, 2015
2answers
I have a Kenmore microwave/hood model #
Try pushing the off/cancel button. It may be that your microwave somehow got into the test mode for the key pad.
6/13/2014 11:54:44 PM • Kenmore 63662 /... • Answered on Jun 13, 2014
My micro wave reads that it is locked how do I
The "lock" function is nice if you have kids who like to push buttons. It disables the microwave oven to prevent it from running unnecessarily,To disable the lock feature push the "STOP-CLEAR" button. Then press and hold the "START" button until 'locked' is no longer shown on the display panel.To re-lock it, do the same thing until 'locked' appears on the display.Have a nice day.
10/21/2013 11:36:26 AM • Kenmore 63662 /... • Answered on Oct 21, 2013
Kenmore microwave elite with a F-9 code.
Get rid of your microwave. Studies have shown that microwaves change the molecular structure of the food, causing abnormal qualities and cancer. The inventor of the microwave doesn't use one.
6/5/2012 5:16:06 AM • Kenmore 63662 /... • Answered on Jun 05, 2012
How do I attach a microwave model #721.80413 to the wallI
if this is a above stove brand.. you have to open the top cabinet right on front lip of cabinet are three screws going into microwave... support unit and remove the screws that hold unit
5/26/2012 6:56:44 PM • Kenmore 63662 /... • Answered on May 26, 2012
My Kenmore Elite Ultra Wave Technology microwave
Here are a couple of quotes from another forum:
"Kenmore Elite 36 " over tne counter microwave is supplied by LG made by Gold Star, made in China. It's main problem is the high voltage inverter board supplyed by Sears Parts. If you get a F-9 code on your microwave display screen and the micro quits it's probably this board. Reset the machine by pulling the power plug and waiting an hour. If it is the high voltage board is at fault it will probably fail after 45 seconds of start up. This part is really hard to get at but is less than $100. A qualified technician should be able to remove and repair this item in less than hour. Some techs will quote you $300 labor, don't buy it, it should cost a $100 or less. No need to buy another microwave."
"F-9 on this microwave IS inverter related. There is a service tech troubleshooting document stuffed in behind the control board cover which has some testing proceedures. My problem was the magnatron and checked out bad with the help of this document. It would run for a few seconds making clicks and then say F-9. It has been working great since I replaced the magnatron PN 6324w1a002c."
Note that part numbers mentioned may not for your model.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
BUT once you have the part number from the Sears parts site, you can often get the parts cheaper here
9/13/2011 5:42:10 PM • Kenmore 63662 /... • Answered on Sep 13, 2011
0answers
0answers
Microware oven has burned out
If the junction box in inside the microwave , refer it to an authorised Kenmore agent for examination and possible free repair/replacement.
If it is and external junction box, call a qualified electrician as the contacts were not maintained and kept tight.
1/4/2011 4:14:57 PM • Kenmore 63662 /... • Answered on Jan 04, 2011
I HAVE CODE F9 WHAT NEED TO FIXED COME ON BUT GO
A bad inverter is usually the cause of this code...try to unplug the unit and then plug it back in... if that don't work then you will need to have it checked...
The F9 code can sometimes by caused by a power surge or glitch through the electrical lines.
You can sometimes clear this fault by completely unplugging the microwave for 1 minute.
Plug it back in and see if the fault code returns.
If it does, then you have an internal component failure that will need to be serviced by a technician.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances.
Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged.
A microwave radiation leakage test must be performed on the unit following any internal component repair.
It does not ALWAYS indicate a inverter control board problem however in other brands/models.
LG's service manual (for an example) suggests the f-9 code could be due to line voltage, magnetron, inverter module, "Relay2", or a loose connection between door/magnetron/control pcb.
Other indications might help narrow down these choices before having to pull out your multimeter and crack open the microwave case.
For example, if the microwave works, but heats slowly, then the troubleshooting manual narrows your choices down to magnetron or line voltage problems, and pretty much rules out the other possibilities.
Basic Microwave Oven Troubleshooting Tips
heatman101
12/25/2010 11:40:49 PM • Kenmore 63662 /... • Answered on Dec 25, 2010
F-9 code after running a shrt time
The F-9 error code indicates a defective control board, inverter or line voltage too high
if you have any further questions please message me back Thanks again Rick
12/12/2010 5:15:08 AM • Kenmore 63662 /... • Answered on Dec 12, 2010
We have a Kenmore Elite
raymond_anta, can you please tell me how to solved getting to the bottom screw?
11/3/2010 8:49:55 PM • Kenmore 63662 /... • Answered on Nov 03, 2010
How to unlock control panel
If the model number is correct, you need to press and hold the START button down until the lock icon disappears (roughly 4 seconds). The same procedure is used to lock the panel. This is a designed safety feature to prevent children from manipulating the controls.
These instructions are printed on page 12 of the owner's manual. If you no longer have a manual, you can obtain a replacement copy at managemylife.com. Just enter your model number under the "Manuals" link and your manual is available in .pdf format that you can download or print for FREE.
For your convenience, here is a direct link:
http://www.managemylife.com/mmh/owner_manuals/21573/KENMORE-Microwave-Hood-Combo-L0310077?brand_name_search=63662
If you need further assistance, please post back and let me know. I hope you find this information helpful.
10/7/2010 3:33:24 AM • Kenmore 63662 /... • Answered on Oct 07, 2010
Kenmore oven-microwave 911 41479791 I get E 01 error.
F 11 code. it is a touch pad error.
If you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
9/26/2010 1:22:41 AM • Kenmore 63662 /... • Answered on Sep 26, 2010
Kenmore 63662 / 63664 / 63669 Microwave Oven Logo
Popular Tags
58 questions posted
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Microwave Ovens
Most Popular Question
attach microwave model 721 80413 walli
  • Microwave Ovens
