20 Most Recent Grohe 28444000 Chrome Movario Movario Five Function Hand Shower Only 28 444 Questions & Answers
0answers
Shower head is making high pitched whistling nois
The holes are probably clogged from hard water. Take the whole head assembly and dip it in a bucket of CLR for an hour or so. Then rinse off and give that a try. If your cheap, you can use a bucket of white vinegar and a little bit o water, but the smell is most disagreeable.
2/12/2010 1:54:55 AM • Grohe 28444000... • Answered on Feb 12, 2010
My Grohe Freehander double shower head arm does not stay up, how do I tighten it?
SEE YOUR LOCAL DEALER AND ASK THEM
4/7/2021 11:07:20 PM • Grohe Home • Answered on Apr 07, 2021
Grohe veletto no enough flow on hot water
Step 1
Turn off the water to your faucet.
Step 2
Remove the handle to the faucet. Remove the small screw under the lever handle with an Allen wrench or Phillips head screwdriver, depending on what type of screw is present. Slide the handle back and off the faucet.
Step 3
Remove the temperature control knob, which is the round, dial-shaped fitting over the faucet cartridge. Put the manufacturer-supplied adapter on the cartridge. Line up the lever stop pin with the arrow symbol on the cartridge.
Step 4
Turn on the water and rotate the adapter to the left, or counter-clockwise, until the water temperature is at the level you want. Take note of the number to which the adapter points.
Step 5
Shut the faucet off by turning the adapter to closed and line up the limit stop dial with the number you noted previously.
Step 6
Assemble the faucet by replacing the temperature control knob and handle, then tighten the handle screw. Turn on the water and operate the faucet. If temperature is not set properly, repeat as necessary until you achieve the right setting.
5/13/2019 6:37:51 PM • Grohe Home • Answered on May 13, 2019
Tighten a Grohe shower handle
Hi Timothy, What's the model and if you have a photo will help.
3/17/2019 3:31:41 PM • Grohe Home • Answered on Mar 17, 2019
How to remove U clamp from GROHE 7659000 Chrome Tempesta Shower Holder for Sliding Rails
K zaveri The pole the U clamp is attached to should be able to be removed. My own shower has a similar set up. The pole's top and bottom mount's front has a pop out of which has a screw underneath. Once you remove the screw the top bracket can be pulled aside and the pole removed so the U clamp can be slid off. I hope this design works for you as well Have a good day,
11/15/2018 1:58:16 AM • Grohe Home • Answered on Nov 15, 2018
How to adajust the water temperature on a thermostaic valve # 34124
Hi Franco, This appears to be on a bath tub. You will have to remove your handle to access this control and simply turn the valve left or right as needed to give you more hot or cold water, whichever it is you are needing. You do NOT need to dismantle the faucet to do this adjustment. Just remove the handle and a cover plate is usually all that is needed for the adjustment. Have a great day!
11/15/2018 1:47:07 AM • Grohe Home • Answered on Nov 15, 2018
Grohe Europlus 19881 #2 ,Brand new, recently installed in shower/tub is very stiff and hard to turn. What is causing this and how can it be repaired?
I would remove the handle and escutcheon plate and grab the front of the faucet cartridge with pliers and see if it is hard to turn now. If it is then there must be an issue with the handle being on too tight or it is binding with with the escutcheon plate somehow. If the cartridge is hard to turn after removing the handle etc. I would pull the cartridge out and grease it using heat proof grease (Plumber's grease) and reinstall it. Make not of it's position when you remove it so as to reinstall in the same position. There isn't any reason I can think of other than the above for the faucet to not turn easy.
11/15/2018 1:39:57 AM • Grohe Home • Answered on Nov 15, 2018
How to replace a GROHE 46 298 KHO
Replacing GROHE 46 298 KHO is as like as replacing other shower heads. 1. Remove old one. 2. Remove excess materials 3. Wrap with teflon tape 4. Install your new GROHE 46 298 KHO Thanks.
10/15/2018 12:14:19 PM • Grohe Home • Answered on Oct 15, 2018
Grohe shower bracket loose
Had the same issue, my suggestion is: 1) find out what model it is 2) go to the Grohe site and go to the tech specs of the glider element 3) for my unit you need to insert a 3" Allen key into the hole in the center of the holder unit and tighten.. worked for me http://cdn08.grohe.com/lib/1/tpi/766909.pdf
6/27/2018 3:20:39 PM • Grohe Home • Answered on Jun 27, 2018
Grohe 28444000 Chrome Movario Movario Five Function Hand Shower Only 28 444 Logo
Popular Tags
4 questions posted
Top Grohe Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Grohe Home Expert? Answer questions, earn points and help others
View Most Popular
Grohe Home
  • Grohe Home
Most Popular Question
shower head making high pitched
  • Home
