20 Most Recent
Grohe 24'' Relexa Shower Bar with Swivel Hand Shower Holder - 28666/Choose Questions & Answers
We installed a Grohe Relaxa Plus 10 years ago.
Likely a blockage in the line. Corrosion or other damaged parts. Try cleaning the filter screen first. Check for normal water flow without the shower unit attached to the spout. If OK, then the unit is the issue.
Install grohe shower bar
After removing from wall by unscrewing long screws after removing cap, look inside and you will see a white translucent plastic with 4 wide, flat hooked ends. Take a small screwdriver and gently push each 4 plastic hooked ends and it will come unhooked from the small groove. Push it far enough that the bar will slide out. No need to remove the plastic hooked piece. To replace, push in each hooked end and push in from the opposite end to reinstall.
Exact same problem.
if you call grohe they will probably send you a free one if it hasn't been over their warrenty period
Grohe veletto no enough flow on hot water
Step 1
Turn off the water to your faucet.
Step 2
Remove the handle to the faucet. Remove the small screw under the lever handle with an Allen wrench or Phillips head screwdriver, depending on what type of screw is present. Slide the handle back and off the faucet.
Step 3
Remove the temperature control knob, which is the round, dial-shaped fitting over the faucet cartridge. Put the manufacturer-supplied adapter on the cartridge. Line up the lever stop pin with the arrow symbol on the cartridge.
Step 4
Turn on the water and rotate the adapter to the left, or counter-clockwise, until the water temperature is at the level you want. Take note of the number to which the adapter points.
Step 5
Shut the faucet off by turning the adapter to closed and line up the limit stop dial with the number you noted previously.
Step 6
Assemble the faucet by replacing the temperature control knob and handle, then tighten the handle screw. Turn on the water and operate the faucet. If temperature is not set properly, repeat as necessary until you achieve the right setting.
5/13/2019 6:37:51 PM •
Grohe Home
Answered
on May 13, 2019
