20 Most Recent
Cifial Hi-Arch Widespread Lavatory Faucet CIFIAL 245.150.625 Questions & Answers
Installation instructions plumbing
He put the wrong faucet in the cold-water side.. There may be a way to change the direction without changing the faucet... but, if there is, I don't know about it... I think you need to make the plumber come back and fix it right.. I had that problem in my shower after a plumber worked on it.. I almost burned myself to death trying to adjust the temperature.
I have a "thunderstorm"type head
There is nothing like a repair kit for the hand held attachment unless you want to purchase a replacement hand held attachment. When the hand held segment begins to leak and "O" rings don't solve it then it is usually a sign that the hand held attachment is due to be replaced. After usage for a certain period the hose for the attachment as well as the aluminum used to make the hand held part begins to suffer from wear and tear and therefore the hose has multiple holes which brings about leakages and the aluminum also suffers from corrosion and begins to have cracks which also causes leakages.
Best option is to order a replacement kit for the hand held segment as that usually is the best repair kit available.
Hope this solution has been helpful?
2/13/2011 12:13:22 AM •
Cifial Home
Answered
on Feb 13, 2011
I have a flat shower
Sorry to read about your problem, I hope this helps you out.
you do not have a experienced plumber find another one
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
12/23/2010 4:01:16 PM •
Cifial Home
Answered
on Dec 23, 2010
What are the different types of powder coating?
Thermoplastic and thermoset are the two types of powder coatings used by leading
Powder coating services. Thermoplastic coating don't undergo any chemical change when heated. Therefore they can be softened and hardened by heating repeatedly. Unlike thermoplastic coatings thermoset coatings changes into infusible materials on heating. Nylons and vinyls are thermoplastic while acrylics and polyesters are thermoset.
4/24/2024 12:02:34 PM •
Home
Answered
Yesterday
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
on Apr 16, 2024
Lost half of my jets on one side of the tub only.I have tried closing the jets that do work half,does not make a difference to the jets not working.Would it be best to empty the tub and start over?
it's likely due to an air lock. Here's what you can do to resolve this issue:
Manually Clearing an Airlock:
Run the jets on low for about 30 seconds.
Then run the jets on high for another 30 seconds.
Repeat this process 3 or 4 times.
If you hear a gurgling sound and see air bubbling up, continue running your hot tub until it pushes all the air out.
If this doesn't work after several attempts, try a different approach.
Bleeder Valves or Pump Method:
Some spas have bleeder valves that allow you to bleed air out of the lines.
First, turn off the spa at the breaker.
Access the pump and loosen the valve to allow the air to escape.
When the air has bled out (you'll notice it turns from hissing air to a stream of water), close the valve.
Run the pump to ensure the jets are now pumping water as expected.
Why Are the Jets Not Working on One Side Only?:
Many hot tubs have two water pumps.
If the jets on only one side of your hot tub stop working, there could be an airlock in only one of the pumps.
It could also be a blockage in the jet lines for that side or a problem with the internal mechanism of the jet itself.
Can You Use a Spa with an Airlock?:
It is not recommended to use a hot tub with an airlock.
4/3/2024 4:33:08 AM •
Home
Answered
on Apr 03, 2024
Restarting my marcel hour strike quartz clock nrms603.
To restart your Marcel Hour Strike Quartz Clock NRMS603, follow these steps:
Stop the Pendulum: Gently stop the pendulum from swinging by holding it still.
Remove the Battery: Open the clock case and locate the battery compartment. Remove the existing battery.
Wait for a Minute: Leave the clock without a battery for about a minute to allow any residual charge to dissipate.
Insert a New Battery: Insert a fresh battery into the compartment, ensuring the correct polarity (usually marked on the battery holder).
Start the Pendulum: Gently release the pendulum and let it start swinging.
Set the Time: Use the clock's time-setting knob or buttons to adjust the time to the correct hour and minute.
Your clock should now be restarted and keeping time accurately
4/3/2024 4:30:05 AM •
Home
Answered
on Apr 03, 2024
