20 Most Recent
KitchenAid 36 in. KECC568 Electric Cooktop Questions & Answers
Fault Codes Kitchen Aid cooktop
F03 One or more eyes permanently pressed. Recommend that the glas be cleaned and all objects removed.<br />
Unplug the unit for one minute the plug back in if the error still remains after returning power then you will need to replace the touch control module.<br />
<br />
F12 Electronic board and touch module communication error.Unplug the unit for a couple of minutes.Restore the power if the error return then you will need to replace the board connection cable between the touch control module and electronic control. if the error remains replac ethe electronic control board. If the error comes back again replace the the touch pad.<br />
<br />
F13 Internal CPU checksum error.Recommend you replace the touch control module.<br />
<br />
F22 Key sensitivity problem.Turn power off to unit for a few minutes,if the error returns after power is restored replace the touch control module<br />
<br />
F36 Temperature probe hardware error.Recommend that you replace the touch control module.
I need tio hook up a 4 wire cooktop(Bl R, W,
hi my name is mark, you need to check local electrical code before wiring cooktop. if it is allowed the white and ground/copper can be tied together with green from house. but if not allowed you will have to run a seperate white wire or new 8ga 3 wire/ with ground from breaker box. check the code first. and shut off power before you wire cooktop. thanks for your question.
