KitchenAid Dishwashers • Uploaded on Aug 26, 2013
Hi
First make sure that nothing is blocking the drain pump
assembly located inside the lower front panel of the dishwasher. If the issue
returns after its cleaned then try to reset the dishwasher control by pressing
the HEATED DRY button and hold it for 15 seconds, if its still not resolved
then it means that the control board has gone bad and should be replaced. Hope
this helps...please post back for further assistance.
Daniel
Hello
& Welcome to FixYa
The problem is with the
dispenser door assembly and its recommended to replace it completely rather than
just replacing the latch. Please get back to me if you have any other questions.
Kevin
Pressing the following option keys in the sequence shown will either
start the Diagnostics Cycle:
HI TEMP WASH, AIR DRY, HI TEMP WASH, AIR DRY
or
POWER SCOUR, AIR DRY, POWER SCOUR, AIR DRY
(HI TEMP WASH = HIGH TEMP WASH = WATER HEAT)
(POWER SCOUR = SUPER SCRUB)
(AIR DRY = ENERGY SAVER DRY = NO HEAT DRY)
All lights should light up and then press the On button to see if all lights turn off.
(Don't worry if there is no change as it may not be the correct buttons on your model).
If the water is not hot then it is possible the heater is faulty. See this diagram.
Please post a comment to confirm what you see.
53 questions posted
480 Questions
217 Questions
151 Questions
124 Questions
109 Questions
