20 Most Recent
KitchenAid 24 in. KUDG25SH Built-in Dishwasher Questions & Answers
Dishwasher door latch
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
Water is leaking from the bottom of the
Either the door seal is leaking from old age or misalignment or the shutoff float is stuck allowing the tub to become over filled. The shutoff is visible on the floor of the washer. It should move freely up and down and the switch below can be heard when manually moving it up and down.
No water going into the dishwasher after a new
did you check the float assy if stuck in the up position it could be in full position due to soap/gunk buildup or something under it it is located towards the front by the door under the rack.
Help! Same white residue and even pro can't figure it out!
It sounds like a washability problem. A couple of things to check.
See if the bottom and top spray arms are free turning. Then look closely at the holes to make sure they are not plugged with anything.
The rest of this applies if you have mode KUDG25SH, if you have a different model number on the tag inside the door let me know and ignore the rest here.
You may have a split in the upper spray arm feed tube. If you slide the upper rack out and look under it you will see the spray arm(propeller looking) under and behind there is a vinyl tube also attached to the rack, look that tube over good, if it is broken or cracked you are loosing water pressure that does the washing.
Let me know what you find and I can help more if needed
Phil
Dishes and glasses are
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
The dishwasher leaks.
Check the following in the same order as i mentioned :-
Main tub seal
Note…
If the main motor of your dishwasher is mounted vertically, beneath the
center bottom of the dishwasher, the following instructions probably
apply to you. But if your motor is mounted horizontally, the pump isn't
serviceable--you need to replace the entire pump and motor assembly.
The
main tub seal is beneath the drain impeller. It prevents the water in
the dishwasher from leaking out near the shaft of the motor. To get to
the seal, which is inside the dishwasher, remove the:
Lower rack
Spray arm
Spray arm support
Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over
time, door gaskets and seals harden and lose their ability to seal
properly. You can't repair the seals. You need to replace them if
they've begun to leak.
Water-inlet valve
The
water-inlet valve, itself, seldom leaks. But, the water-supply line
from the house and the rubber tube leading from the valve to the inside
of the dishwasher may leak. Tighten or repair/replace these as
necessary.
The
water-inlet valve could mechanically stick open. When that happens, the
water continues to flow into the dishwasher, which then floods your
kitchen. Turn off the water supply to the dishwasher, and replace the
valve.
Hoses
Behind
the lower access panel on your dishwasher are several rubber or plastic
hoses. If the leak appears at a connection, try a new clamp. If that
doesn't work, replace the hose.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
It was running, most of
Yes that might be one of the reasons. Whenever there is Drain Problem in dishwashers, always follow the below sequence to narrow down the fix :-
Drain line/air gap
A
clog in the drain line or air gap (if there is one) is the usual reason
that a dishwasher won't drain. Often the problem is at the point where
the drain line attaches to the garbage disposer or household drain
line. If you remove this line, you can clear any debris from the hose
or hose connection. Be sure to reattach the hose before starting the
dishwasher again.
Pump
Your
dishwasher pump ejects the water. The pump is usually mounted directly
to the motor, then attached to the bottom of the dishwasher. You can
reach the pump from inside the dishwasher, but first you need to remove
the lower rack, the spray arm, and the spray arm support.
Look
for an impeller--a round plastic fan blade-type of device that spins
around. This is the wash impeller, which forces the water through the
spray arm. Beneath the wash impeller is the drain impeller, which is
similar in size and shape to the wash impeller. The drain impeller
pushes the water toward the drain port. These components make up the
pump. If any of the pump components are defective, you need to replace
them.
Drain valve and/or solenoid
Many
dishwashers use a drain valve with an electric solenoid. When
electricity flows to the solenoid, the valve opens and diverts the
water to the drain. Sometimes the solenoid, or the diverting lever,
sticks and prevents the dishwasher from draining or filling properly.
Try to free up the solenoid to lubricate the lever. Otherwise, you may
have to replace the solenoid or pump assembly. With these systems, the
motor always rotates in one direction. When it's energized, the drain
valve diverts the water.
Other
dishwashers simply reverse the direction of the motor to drain the
dishwasher. These units don't have a drain valve. Instead, there's a
drain hose connected directly to the pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If
the motor isn't turning or working, the unit won't drain. First check
to be sure you have power to the dishwasher. If not, see the section
"It doesn't work at all." If the motor hums but doesn't turn, it may
need to be replaced.
Some
dishwashers are susceptible to getting stuck if you don't run them
regularly. If you haven't run the dishwasher for more than a week, you
may need to manually spin the motor to free it up. If the motor is
defective, you need to replace it. Dishwasher motors can't be serviced.
Timer
Part
of what the timer does is control the motor and drain valve. If the
timer doesn't work properly, the water may not drain and you need to
replace the timer. This problem is uncommon.
Hope i helped you.
KitchenAid KUDG25SH stopped running,
Maybe a peanut or piece of bone stuck in it. What have you been eating that may have gone thru filter trap.
Remove pump and blow back with outdoors hose - worth a try.
PS Was it a peanut?
Kitchedaid dishwaser child lock light is on
from my experience press the last function key and hold that should turn it off, if that doesn't work press the temp and hold or the energy save, the key is to hold it and try and see the last function key that was pressed.
