20 Most Recent KitchenAid KUDR01TJ Dishwasher Questions & Answers
0answers
Pump seal removal
Please confirm if this is the pressure pump and if so the seal must be replaced with the correct type specially if it has worn out. Also make sure that the fitment is tight and even so that there is no air gap for leak so as to reduce the pressure.Source the seal gaskets from the service dealer.
12/6/2011 11:17:44 AM • KitchenAid... • Answered on Dec 06, 2011
Water does not drain from diswasher
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
4/1/2011 8:47:25 PM • KitchenAid... • Answered on Apr 01, 2011
Dishwasher not cleaning. Dishwasher turns on,
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
3/27/2011 7:02:24 PM • KitchenAid... • Answered on Mar 27, 2011
Ditches come out looking very dull, glasses look
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
3/2/2011 4:17:36 PM • KitchenAid... • Answered on Mar 02, 2011
Kitchenaid dishwasher KUDI01TJWHO will not drain.
Hi Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
2/10/2011 2:29:56 AM • KitchenAid... • Answered on Feb 10, 2011
Pump very noisy, especially when draining. How do
remove it from the counter, unhook it, get something to tilt the front forward and get under it... Might not be the pump itself, is there a screen in the drain - or has something managed to get past that initial out drain?
Best regards
Ck
1/17/2011 6:41:49 PM • KitchenAid... • Answered on Jan 17, 2011
When I turn on dishwasher, water not cycling
you may have a defective water intake valve. common problem
Please give rate/vote on this response thanks
12/19/2010 10:03:06 PM • KitchenAid... • Answered on Dec 19, 2010
How can I find a possible leak?
Here is a tip that I wrote about dishwashers and them leaking.Leaking Dishwasherheatman101
11/12/2010 9:59:58 AM • KitchenAid... • Answered on Nov 12, 2010
Water not draining after washer stops
This means you have a problem with the pump, not pumping out the water it is probley filled or jamed with lint.
10/26/2010 2:33:47 AM • KitchenAid... • Answered on Oct 26, 2010
Need to replace door latch. Do I access it by
only the top half screw's would be enough, the pannel should popout then...
10/12/2010 11:26:18 PM • KitchenAid... • Answered on Oct 12, 2010
There is water sitting in the bottom after all the
9 times out of 10 there will be debris stuck in the pump impeller... access from the bottom of dishwasher by tilting to side or back... common fault...
10/12/2010 10:13:28 PM • KitchenAid... • Answered on Oct 12, 2010
Lower seal on dishwasher leaks
vcx
9/29/2010 3:08:19 PM • KitchenAid... • Answered on Sep 29, 2010
KitchenAid KUDR01TJ Dishwasher Logo
77 questions posted
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Dishwashers
Most Popular Question
ditches come out looking very dull
  • Dishwashers
