20 Most Recent KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher Questions & Answers
9answers
Whirlpool Dishwasher - lock
This solution is AWESOME...dead on and my unit is back up and running...Thank-You SAS
12/4/2016 1:07:08 PM • KitchenAid 24... • Answered on Dec 04, 2016
The bottom of the tub is full of water won't drain,any idea
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If it's still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps...
5/17/2014 12:38:16 PM • KitchenAid 24... • Answered on May 17, 2014
0answers
0answers
2answers
Upper spray arm tower came
You can find a replacement for the upper spray arm (3rd level). Kitchenaid #8268298. See www.pcappliancerepair.com. Their part number is 8193504. $9.15 plus shipping. Good luck and happy holidays.
Joe
6/25/2013 7:40:59 PM • KitchenAid 24... • Answered on Jun 25, 2013
No dry heat
Sounds like ur heating element has blown but because u also say light doesn't work check 4 power at plug or wall socket if this ok then check ur fuses in plug and fuse box on the wall if all ok then un screw bulb and replace like 4 like also same applys 4 the heating element hope this helps u
9/3/2012 1:26:23 PM • KitchenAid 24... • Answered on Sep 03, 2012
Dishwasher won't start
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched
The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate.
It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
8/18/2012 12:45:34 AM • KitchenAid 24... • Answered on Aug 18, 2012
Dishes are not cleaned at all. The dish washer
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
8/29/2011 5:04:07 AM • KitchenAid 24... • Answered on Aug 29, 2011
I have a kitchenaid dishwasher
Hello, Thank You for using FixYa. I will be helping you today.I would start by removing the outer door panel remove the screws around the inner door to do this.Then close the door and start a cycle. Sometimes you can see obvious signs of leaks just by removing the panel too. But if not let it run and see if you see water leaking anywhere. You will see water in the bottom corners its normal. If water is splashing over those corners the check the lower spray arm gor damage or cracks it can cause this problem also make sure the screws under the spray arm are tight. also check the upper arm.
Thank You and please rate my answer if it was helpful..
6/12/2011 4:12:17 PM • KitchenAid 24... • Answered on Jun 12, 2011
I found that part #
Hello, Thank You for using FixYa. I will be helping you today.You can get it cheap from amazon http://www.amazon.com/Whirlpool-Upper-Wash-Spray-8193504/dp/B001DHLD78
all you have to do is pull down on the top water delivery tube all the way in the center top of the unit some have one screw and some have a bracket holding it up. You only need an inch or so to get the white plastic center lock that comes with the new one in there then hold the spray arm up there and push the new lock clip into the first piece you just put in from the top.
6/11/2011 12:32:21 PM • KitchenAid 24... • Answered on Jun 11, 2011
Kitchen aid KUDM01TJWH0 dishwasher- stopped
I have same problem. I can't find the Troubleshooting diagnostic instructions. These are usually hidden somewhere on the washer. Do you know where they are?
5/17/2011 1:00:58 AM • KitchenAid 24... • Answered on May 17, 2011
My dishes are not getting clean. There is dirt and
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
5/1/2011 12:19:10 AM • KitchenAid 24... • Answered on May 01, 2011
Water will not drain out. do not have a drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
3/29/2011 4:00:11 AM • KitchenAid 24... • Answered on Mar 29, 2011
KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher Logo
75 questions posted
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Dishwashers
Most Popular Question
found part
  • Dishwashers
