20 Most Recent
KitchenAid 24 in. KUDP01FL Built-in Dishwasher Questions & Answers
I have a KitchenAid model
what makes you think it was in a demo mode ?? was it a floor demo model ? as if it was there might be a few things you needed to reconnect before you use it in your home , one that comes to mind is the float level switch , this is usually in front right corner and demo models usually have a foam spacer under there edge , also its possible a demo model could have a special control board in them , requiring you to replace it with a standard model b4 it would work properly
How to remove the upper rack on kitchenaid dishwasher
The upper rack has a captive washer with a lug that stops the top drawer from falling out. Use a torch, identify the captive washer that is connected to the rear wheel on each side if the drawer, remove these and the draw will come out
Kitchenaid KUDP01FLSS0 won't start. Checked breaker and still nothing. what next?
Turn off the braker then , I would open the front lower electrical box most times on the right hand side near the floor , you have to remove the small lower cover first, open the small electrical box, you should see a black wire and a white wire and also a green , once you have expose the two wires and they aren't touching anything , turn on the power again , now take a tester set it to voilts , take the two wires from the tester and put one on the black and one on the white and see if you have power there, should be around 120 voiltsBefore you pull this apart dose the door handel feel funny ? there are safty switches on the door handel thats why i was asking and this will also make the unit go dead , let me know what you find out
Kitchenaide KUDP01FLWH1 cancel and normal
Hello, mark
I was trying to help
you out here. I was going back to some customers that asked questions
in the past and it appeared that no one answered them, so I thought I
would take some of my personal time to see if I can help. Even though
this site may not have your exact model or brand, This link will help
you tons. Here is a link
to about everything you want to know about your dishwasher, from repair
to trouble shooting it,pictures, video's. Just scroll around and you
will see tons of information to almost any question you might have on
your dishwasher. If you go to this link and click around, I am sure you
will find out so much about your dishwasher, you will know more that the
company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Kitchenaid dishwasher kuds220t3 won't start
Hello, star
would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link
Thanks,Mike
Top row dishes are not cleaning
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher
SprayArms not Spinning
How to Buy
ApplianceParts OnlineA bad heating element causes many problems in dishwashers...
Dishwasher Problems The
HeatingElement not WorkingDishwasherMaintenance
DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
