20 Most Recent
Moen & Villeta Two Handle Lavatory Faucet Questions & Answers
I have a handle that
Sorry to read about your problem, I hope this helps you out.
under the moen symbol is a set screw
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
I was able to figure
I took a look at the brand on the web and though I do not know your model, it appears that the center spout would have to be loosened from down under the sink and then pulled up from the top. Those units usually come in three parts, two valves and the spout. The valves are put in from under the vanity/sink and the spout is put in from above the vanity/sink.
HAVE MOEN MODEL INS792A WIDESPREAD
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Faucet is dropping it is a one handle
First turn water supply to faucet off and remove handle. Remove cartridge from inside faucet and replace with new cartridge. Make sure you tighten cartridge to snug. Don't over tighten.
Facet leaking
You can purchase a replacement cartridge for that... most hardware stores or places like Home Depot or Lowe's will have them. Take in the old acrtridge or the model of thefaucet. Some of them need a special puller to get the old cartridge out..
heatman101
I have a loose handle on my Moen two hanlde
Take handle off and check out the inside to make sure it not striped out and on the top of the handle it may have a plastic cap to pop of to access the screw holding in in place you amy have to use a knive to get it off .
If you can't see a set screw it may have a screw in handle on top.
My moen 2 handle faucet one handle came off. my
with the handle placed over top,as if it where in the off position start threading (screwing) it back down, while holding the lever in the closed position.as you screw down you will feel it engage the teeth on the stem,it may take a few attempt's,you may have to "play"around w/it to get right position.
How do you take a moen bathroom Model #:
On the handle it self you should see a red and blue button plug. Remove this and you will see set screw. Remove handle, remember to shut off hot and cold water supplies under sink before you go any further.
