20 Most Recent Danze & Sunflower Showerhead Questions & Answers
Danze sunflower shower head only works with cold water
Hi, same problem i had faced and that time i didn't have much knowledge about pipe setting or plumbing stuffs.Please check the shower setting connections and make sure the hot water is in active mode or check the internal connection for pipes with faucets.i have given link for more information for showers . http://www.a-general.com
9/4/2014 1:12:00 PM • Danze &... • Answered on Sep 04, 2014
Danze D500044 switch control arm loose, can't switch the water from shower head to bathtub, how to fit it ? Thanks
you may need to adjust the diverter cartridge on the valve to fix the switch control arm. Here are the steps to do so: Turn off the water supply to the faucet and open the valve to release any residual pressure. Remove the handle by loosening the set screw with an Allen wrench and pulling it off. Unscrew the bonnet nut and remove the diverter cartridge by pulling it out with pliers. Check the O-rings and seals for any damage or wear and replace them if necessary. Align the diverter cartridge with the valve body and push it in firmly until it snaps into place. Screw the bonnet nut back on and tighten it with a wrench. Reattach the handle and secure it with the set screw. Turn on the water supply and test the faucet for proper operation. I hope this helps you fix your faucet. If you need further assistance, please contact Danze customer service at 1-888-328-2383.
3/7/2024 3:37:36 PM • Danze Home • Answered on Mar 07, 2024
Danze faucet jerks
being a new faucet it does that because you still have air in the line. turn the faucet on and let it run for a while, if that doesn't work take it back and get a better quality faucet like a delta, because they make them so cheap that the seal could be loose inside.
3/31/2019 3:50:35 PM • Danze Home • Answered on Mar 31, 2019
2answers
On OpulenceTM SHOWER Trim Kit w/8incg Sunflower
Either this is a consequence of having a "low-flow" shower head, or the pipes are too small or have too many bends and elbows to support the flow rate required at 65 PSI for such a large shower head. What is the water pressure at the shower head fitting while the shower is running? It won't be 65 PSI, but it shouldn't be below the recommended inlet pressure for the unit.
2/27/2018 4:55:18 AM • Danze Home • Answered on Feb 27, 2018
We were trying to stop a leak in a danze songle handle shower faucet now the hot water won't turn off whar do we do?
you need a new cartridge if its fairly new. if its an older faucet it will have to be replaced, usually the hot water side warps the fixture and it leaks there nothing you can do about it except to replace it.
9/20/2017 1:59:41 PM • Danze Home • Answered on Sep 20, 2017
2answers
Why is there no cold water coming out of my shower head
if you live some where that gets cold one of your pipes could have frozen. if you can get to the crawl space/basement put a heater down there for a few hours and leave the shower cold water on if the water comes out of the shower your pipes have thowed out. here is a video https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&uact=8&ved=0CDMQtwIwBGoVChMIn6q266OQyQIVAs9jCh3O6QFj&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DPbnGn9EG1mw&usg=AFQjCNEMOGXppMYQl-Rcij9L-P36CdC8Rw&bvm=bv.107467506,d.cGc good luck
11/25/2015 11:56:15 AM • Danze Home • Answered on Nov 25, 2015
New danze cartridge no water
Possible issue with pressure balancing cartidge, When you remove parts, turn off water, remove parts, slowly turn on water and see if brass valves lets water out. If yes pressure balancing cartridge or cartridge itself is defevtive.
8/16/2014 10:32:51 PM • Danze Home • Answered on Aug 16, 2014
How danze shower lever which changes the water flow from the permanent shower head to the removeable freehand shower has fallen out. How can it be repaired?
Don't try to repair it. Replace it. All hand held showers use 1/2" hose fittings so any brand divertor should fit. Bring the part with you as there are different styles.
8/11/2014 10:36:30 PM • Danze Home • Answered on Aug 11, 2014
How to install a cartidge shower 1 handle separate PB
make sure that you have installed the right way not upside down or backwoods...pull back out and check the alignment....good luck
7/18/2014 2:20:56 PM • Danze Home • Answered on Jul 18, 2014
0answers
Danze c600190
Be the first to answer 7/3/2014 3:15:07 AM • Danze Home • Posted on Jul 03, 2014Be the first to answer
Shower head holes clogged up
unscrew head with cresent wrench...soak head in viniger over night....this should clear holes...wash out...if has restrictor...remove and replace using teflon tape..
5/22/2014 11:23:43 PM • Danze Home • Answered on May 22, 2014
Danze UPC tub/shower valve leaks
shut off water and pull cartridge...go to lowes or plumbing supply and match up cartridge and replace...you may also just replace seats and springs if cartridge is ok....cheaper...but if not sure just replace whole cartridge...make sure hot is on left...
5/22/2014 9:59:26 PM • Danze Home • Answered on May 22, 2014
I have danze single handle shower head leaks when turned off
you need new seats and springs that are in cartridge...replace them or buy the whole cartridge and replace that....turn off water and install new one you can buy at lowes or your nearest plumbing supply...good luck
5/22/2014 9:17:04 PM • Danze Home • Answered on May 22, 2014
Ceiling mounted shower head (Danze) leaks water for a good 30-40 seconds long after being turned off
you really can not because of the overhead piping holds lots of water and so does this big head....that is just normal for these things...i am a licensed plumber for over 34 years and have done these...its just draining out all the overhead water....
5/22/2014 8:55:46 PM • Danze Home • Answered on May 22, 2014
Danze & Sunflower Showerhead Logo
1 questions posted
Top Danze Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Danze Home Expert? Answer questions, earn points and help others
View Most Popular
Danze Home
  • Danze Home
Most Popular Question
danze sunflower shower head only works
  • Home
