20 Most Recent
Danze Sheridan Tub & Shower Faucet Questions & Answers
We have a pressure balance tub and shower faucet
you have to turn off water ....remove cartridge and use heat proof plumbers grease on all inner and outer parts of value and cartridge and body...do not be shy with grease...this should make it better than new...if not buy a new cartridge then grease all...try first to see if works..
The Fairmont has no apparent
they either have a small cap on front to pop off then screw under cap..or they have under or to side of handle a very tiny set screw recessed...it is a allen screw...loosen and pull out...
How to remove cartridge for
pull handle...unscrew big nut and pull straight out...may take some force...reinstall hot side to left...after cooling...turn on water test for leaks
Hansgrohe tub spout spray orangey water when first turned on
The only cause for this is iron pipe being used somewhere in the system. This is commonly found between the drop eared 90 in the wall and the tub spout. Most likely your installer has used an iron pipe nipple at this location. We recommend using a brass nipple to avoid rusty water. If you need more help feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for Tech and ask for David Scarborough.
Danze D500044 switch control arm loose, can't switch the water from shower head to bathtub, how to fit it ? Thanks
you may need to adjust the diverter cartridge on the valve to fix the switch control arm. Here are the steps to do so:
Turn off the water supply to the faucet and open the valve to release any residual pressure.
Remove the handle by loosening the set screw with an Allen wrench and pulling it off.
Unscrew the bonnet nut and remove the diverter cartridge by pulling it out with pliers.
Check the O-rings and seals for any damage or wear and replace them if necessary.
Align the diverter cartridge with the valve body and push it in firmly until it snaps into place.
Screw the bonnet nut back on and tighten it with a wrench.
Reattach the handle and secure it with the set screw.
Turn on the water supply and test the faucet for proper operation.
I hope this helps you fix your faucet. If you need further assistance, please contact Danze customer service at 1-888-328-2383.
3/7/2024 3:37:36 PM •
Danze Home
Answered
on Mar 07, 2024
Danze faucet jerks
being a new faucet it does that because you still have air in the line. turn the faucet on and let it run for a while, if that doesn't work take it back and get a better quality faucet like a delta, because they make them so cheap that the seal could be loose inside.
3/31/2019 3:50:35 PM •
Danze Home
Answered
on Mar 31, 2019
On OpulenceTM SHOWER Trim Kit w/8incg Sunflower
Either this is a consequence of having a "low-flow" shower head, or the pipes are too small or have too many bends and elbows to support the flow rate required at 65 PSI for such a large shower head. What is the water pressure at the shower head fitting while the shower is running? It won't be 65 PSI, but it shouldn't be below the recommended inlet pressure for the unit.
2/27/2018 4:55:18 AM •
Danze Home
Answered
on Feb 27, 2018
