20 Most Recent
Moen Posi-Temp Single HandleTub And Shower Faucet Questions & Answers
Replaced delta valve with moem.
The pipe going from the main valve to the tub spout(not the sprayer above)needs to be a full 1/2" pipe if you used a pex 1/2" to the tub spout-the inside is usually smaller and causes it to back pressure and make water release thru the sprayer above-needs to be installed with a full 1/2" ID PIPE-AND DONT USE GALVANIZED
Water on/off is in the wrong position after changing the moen cartridge in my shower
Put your cartridge back the way it was originally. By rotating 180 you reverse the hot and cold. Leave the handle and plastic adapter off. Turn on your water supply and turn valve with the plastic adapter until the water is shut off. Remove the adapter and install it with the set screw for handle facing down. Put your handle back on and that should take care of problem. (I did the exact same thing as you today....small world)
Low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Ice maker won't fill
Try finding the water source-turn it off-then on again after 10 min. Some ice makers have a reset button- check manual.
Had a leaky Moen Posi-Temp shower faucet.
I'm not aware of any problems with non moen replacement parts being the cause for a water hammer problem. Start with the simplest and cheapest correction which is using a moen replacement cartridge. If the water hammer persists then you may have to install a water hammer arrester in the plumbing system. This is basically a shock absorber in the plumbing system to stop the effect of water hammer. An arrester will cost you around $10 to $15 at your local plumbing supply shop. If you are not comfortable soldering copper then you will want to hire a licensed plumber to complete the work for you.
I had the same type of problem with an older toilet in my house. It developed a water hammer when it shut off after filling the tank. I replaced the fill valve with a generic universal replacement for about $10 and it stopped. Again sometimes the simplest fix will work. Let me know how it works out.
The water does not completely
The seals located in the faucet's cartridge will wear out over time, causing water to drip uncontrollably from the faucet. These worn out seals can also make it difficult for you to turn the water in the tub completely off.
This is often caused by a scratched or torn cartridge, O-ring, or grommet. Typically, a cartridge replacement will correct this type of leak or water dripping.---------
Click the link below and follow the troubleshooting directions:---
http://technoanswers.blogspot.com/2011/07/water-does-not-completely-shut-off-on.html
This should help.Thanks.Helpmech.
PIPE TO SHOWER HEAD IS SEIZED ANY SUGGESTIONS FOR
Good Afternoon, GWBreish:
If the 'seize' is from hard water (white or green deposits on the fixture) a towel or sponge soaked in vinegar or CLR van be tied or velcro bagged onto the fixture for 15 to 30 minutes, then the residue attacked with a scrubber or steel wool pad. If the seize in inside the fixture, you will have unscrew the face plats and paint or swab CLR or vinegar to the meshed parts of the handle.
CHR
