Delta II urinal continues to flush after replacing the diaphragm
Refer to instructions that came with valve body, orgo on line and read them
CONTINUOUS FLUSHING:1.The Regulating Screw (061024A, item #4) may be turned RIGHT (clockwise) TOO FAR. Adjust by slowly turning the Regulating Screw LEFT (counter- clockwise) (except -6, -48, -42, -19 and -05 models which are fixed volume).2.If flush is still continuous, close inlet stop, remove Regulating Screw (061024A, item #4), CLEAN bypass slot in the Screw, REPLACE it in the valve and Adjust slowly for proper flush (except -6, -48, -42, -19 and -05 models which are fixed volume).3.CHECK the relief valve in the Handle Cage (060810A, item #12) and see if it is stuck in the open position or fouled by debris. Replace the Handle Cage(060810A, item #12) if necessary.4.Remove cast cap assembly (see Table 1) and Diaphragm/Guide Assembly (061323A - WC, item #7a or 061324A - UR, item #7b, 061376A - UR,item#7c) and check for contaminants at renewable seat and diaphragm and check for debris in the cap for blockage. Also CHECK that the Diaphragm/Guide slides easily in the Renewable Seat.
6/7/2019 1:36:28 PM •
Delta Home
Answered
on Jun 07, 2019
