20 Most Recent KitchenAid KEMC308 Electric Double Oven Questions & Answers
0answers
0answers
The microvave oven has "door" in the display and the microwave doesn't work
Then one of the micro switches either has failed or has slid out of position
11/29/2013 6:20:13 PM • KitchenAid... • Answered on Nov 29, 2013
manual
Kem308 replace door latch
2/18/2013 9:09:54 PM • KitchenAid... • Answered on Feb 18, 2013
2answers
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
9/12/2012 6:49:31 PM • KitchenAid... • Answered on Sep 12, 2012
4answers
KEMC308 Microwave oven door
Had the same problem and bought the part online. It's not difficult to replace, simply hold the door by the handle as you loosen the 2 screws. Put the face of the door on the floor and remove 2 screws holding the plastic insert. You will have to remove the front vent panel (2 Screws) just below the microwave door.Then you might have to move the oven vent over to get to the final 2 screws on the bottom of the plastic panel. Once you have the palstic panel off the springs are exposed, simply look at how it is placed in the holder before you remove the damaged one. Replace and then re-assemle the door.
10/14/2011 2:39:14 PM • KitchenAid... • Answered on Oct 14, 2011
The power won't come on
Hello, Thank You for using FixYa. I will be helping you today.It blew the thermal fuses one on the back and one on the control replace both even if its just one.The one on the back top oven is part 9759243 and the control one is 4456654. For the back one you have to pull the oven out and the control one remove the front side rails then the control side screws to open the control
Thank You and please rate my answer if it was helpful..
6/11/2011 6:28:41 PM • KitchenAid... • Answered on Jun 11, 2011
2answers
KEMC308KSS04 Micro/Oven combo is not heating. The
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
3/28/2011 6:21:03 AM • KitchenAid... • Answered on Mar 28, 2011
4answers
KitchenAid KEMC308KSS02 Microwave Error
The micorwave oven light does not work and when I push start, the word DOOR shows on the screen and beeps 3 times. The oven will not start.
1/11/2011 12:12:06 AM • KitchenAid... • Answered on Jan 11, 2011
KEMC308 has frozen, unusual looking display info. Nothing works.
Try unplugging it or flipping the breaker to the oven. Leave the power off to it for a minute, then turn it back on.
12/2/2010 4:44:54 AM • KitchenAid... • Answered on Dec 02, 2010
2answers
Panel says "close door' when
That would likely be a faulty door switch. Remove two screws to remove the swich. Then pull the two wires from the switch and replace the switch.
10/19/2010 5:07:46 AM • KitchenAid... • Answered on Oct 19, 2010
The display says auto start reheat hour 23 - none
What happened? I've got the same problem and can't find answers anywhere. I'm divorced with two kids and no money to call someone right now this is incredibly upsetting...please email me if you resolved the problem at [email protected] Mary
10/16/2010 3:50:46 AM • KitchenAid... • Answered on Oct 16, 2010
How do you clean the inside glass on the oven door
You need to take the door off and apart. Glass is very hard to clean as the dirt bakes on it, so if you want it to look like new then just buy a new piece of glass.
6/5/2010 3:21:43 PM • KitchenAid... • Answered on Jun 05, 2010
The top oven door is locked and I can't open. Did
trun oven off at the breaker WAIT 30 MINTUE B4 OPEN oven might be in cleancycle
4/25/2010 2:58:35 AM • KitchenAid... • Answered on Apr 25, 2010
Problems with KitchenAid KEMC308 Electric Double Oven DISPLAY
either the touchpad ur pushin or the control board behind is has a bad connection or one of them is defective......u will prob need service some of those u must pull out to acess the componets, not a cheap repair if one of those, usaually at least a couple hundred dollars per part
2/5/2010 5:01:58 AM • KitchenAid... • Answered on Feb 05, 2010
Light is out in Microwave Oven
You have to pull the complete unit from wall, take top setion apart to get to lamp, do not attempt to change this lamp unless you have knowledge of electricity and what it can do to you if you FAIL TO TURN IT OFF FIRST.
10/1/2009 2:09:38 AM • KitchenAid... • Answered on Oct 01, 2009
KitchenAid KEMC308 Electric Double Oven Logo
36 questions posted
Top KitchenAid Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Ovens
  • KitchenAid Ovens
Most Popular Question
panel says close door when
  • Ovens
