20 Most Recent Kohler Bath Highline K-11492-96 Biscuit The Complete Solution Elonga Questions & Answers
Brand new kohler highline k
most modern flappers(what you call a canister float if i understand you correctly) have some type of adjustment feature which controls this.(like maybe rotating the flapper one way or the other) the old fashioned way was to take up the slack in the chain attached to the flapper so that when someone pushes the handle the flapper is pulled higher. make & model # or a pic would help me say w/certainty how yours works. just text me here if you need anything else and good luck:)
9/17/2014 9:21:12 PM • Kohler Bath... • Answered on Sep 17, 2014
To adjust the level of
not on the float, but on the fill tube cap,, its a small screw that you can adjust the arm drop with the float on the end of it, If its adjusted all the way and is still filling to much,, just bend the bar holding the float down
5/31/2011 3:14:52 AM • Kohler Bath... • Answered on May 31, 2011
2answers
Sewer smell in house since
It sounds like a vent problem.
On top of each house is a vent stack.
There should be a vent stack above each toilet, and above kitchen sink.
Look for pipes sticking out of roof.
These pipes are open to the sewer line.
When you run a column of water down a drain, the vent stack lets air flow in front of and behind the column of water.
This air flow prevents the gurgling sound.
The gurgling sound is the drain water pushing air in front of it because of a clogged vent.
If you have a two story house, there are vents that run between floors to prevent the air flow from gurgling or bubbling sewer air into each drain as water column moves down pipe.
http://www.bradyinspects.com/plumbing-vents.html
http://chestofbooks.com/home-improvement/construction/plumbing/Standard-Practical/Venting-Part-3.html
Look for bird nest over vent pipe on top of house.
Run a snake down into pipe from roof and see if the is a stoppage.
You many need to call plumber to track down each vent and the cause.
For example if there are quick-vents installed inside a wall and the quick vent is no longer working.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
1/12/2011 3:58:06 PM • Kohler Bath... • Answered on Jan 12, 2011
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)? All questions need to start 'make model (what it is)' first 3 words. And then a clear question. For the 13 people that have tagged this 10 year old question, it is better to post your own question. ..
2/7/2024 6:03:08 AM • Kohler Home • Answered on Feb 07, 2024
How do I do a factory reset on a Kohler Hatbox toilet please?
I have never heard of a toilet that needs an electronic reset, but it appears it is as simple as just disconnecting the power for 10 minutes. It does sound though are yours has a failing flush valve. I managed an airport lounge and we had dozens of electronic toilets and we had to keep a box of spares for them and just put new parts in them including complete control boards. We also kept a box of batteries. https://www.google.com/search?q=kohler+hatbox+toilet+factory+reset ..
2/7/2024 5:40:05 AM • Kohler Home • Answered on Feb 07, 2024
2answers
How to remove Kohler 1 piece toilet lid with single pull handle in the middle of the lid
Lift and pull the lid forward lift up and disconnect the lift lever from the chain.
2/24/2023 1:35:18 AM • Kohler Home • Answered on Feb 24, 2023
2answers
How do you tighten the toilet seat on a Kohler Escale toilet?
https://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1095641_2.pdf
10/15/2021 8:04:37 PM • Kohler Home • Answered on Oct 15, 2021
Kohler Whirlpool jets are weak.
Kohler has good support. You can view the diagrams for that unit with the link I am posting. There are no filters listed in the diagram that might need to be cleaned. There is a chance that the unit has developed a clog from hair etc in the pump impellor. The flange may have come loose and is allowing air in the suction side of the pump too. Kohler has online chat and support numbers you can call too. K-1357-RA ' Devonshire 5-Foot Whirlpool with Apron and Right Drain ' KOHLER
8/13/2021 2:05:35 PM • Kohler Home • Answered on Aug 13, 2021
2answers
How to adjust the water presure on a Kohler K-T14422-3 shower head
just turn the water valve down some
5/21/2021 8:50:19 PM • Kohler Home • Answered on May 21, 2021
2answers
How do I fix KOHLER Touchless toilet it keeps flushing, it is less than 6 months old
We had a problem with phantom flushing. Call Kholer. They will send redesigned battery holder and top of flush unit for free. Seems to have fixed the issue.
1/9/2020 11:21:38 AM • Kohler Home • Answered on Jan 09, 2020
How to change the battery in the kohler veil toilet?
The only batteries are in the docking station. If the remote is attached to the docking station, take that off and set it aside. Next, carefully lift the docking station up and out from the mounting bracket. Look at the back of the docking station, push the two tabs outwards (away from each other) simultaneously to open the battery compartment cover. Replace the batteries (4 AAs) in the correct orientation. Reinstall the cover. Then replace the docking station on the mounting bracket and put the remote back on the dock if desired. These directions are shown in the Homeowner's Guide (without the service parts) available on the product page: https://www.us.kohler.com/us/veil-intelligent-comfort-height-skirted-one-piece-elongated-dual-flush-toilet/productDetail/toilets/1120267.htm . Scroll down to the Installation section to find the link to the document. The current link to this guide is https://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1226974_5.pdf . I hope this helps. Cindy Wells
1/5/2020 12:50:49 AM • Kohler Home • Answered on Jan 05, 2020
2answers
What is the best way to remove a ring in the toilet bowl of a new Kohler toilet, In a very hard water area?
I just posted an answer here, but don't see it. ??
5/12/2019 1:13:24 PM • Kohler Home • Answered on May 12, 2019
How do you remove a ring on the bowl of a new Kohler toilet. This is a very hard water area?
The brand of toilet doesn't matter. You need a product that cuts calcium and lime. It may take some soaking and scrubbing. Once you get it clean, use the product regularly. CLR makes a line of products: https://clrbrands.com/en-US/Products/CLR-Household/CLR-Calcium-Lime-Rust-Remover
5/10/2019 9:38:53 PM • Kohler Home • Answered on May 10, 2019
I have a Kohler spa tub. I want to change the air switch on the top of a Kohler Proflex #1157 motor. I cannot seem to figure out how to get the top of the switch off. I cannot find any screw heads.
I don't know this specific tub, but here's the pictoral. The button (90105) should come out of its base, held by friction of O ring. This should allow you to disconnect the pressure line. If you are looking to replace the complete assembly, likely you will need a basin wrench to reach nut (65157). kohler1-ggmuzyqdnvlyrlfigj0gxfoh-4-0.png Here are links to Kohler, specific to this tub. https://www.us.kohler.com/us/catalog/svg_viewer.jsp?productId=415928&diagram=3 https://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1010564_5.pdf
3/18/2019 1:06:40 AM • Kohler Home • Answered on Mar 18, 2019
2answers
Kohler Cimarron toilet wont flush completely. The flush is fast, but the bowl won't empty entirely.
Smart-a$$ answer is to find an old 3 gallon pot in a salvage place. Best answer is to fiddle with the chain that goes from the handle to the flush flapper and see if adjusting its length makes a difference. If it's too short it might result in letting the flapper closing too soon and allowing your deposit to remain.
3/1/2019 1:16:43 AM • Kohler Home • Answered on Mar 01, 2019
Kohler Bath Highline K-11492-96 Biscuit The Complete Solution Elonga Logo
6 questions posted
Top Kohler Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
brand new kohler highline k
  • Home
