20 Most Recent
Duravit 1930 Toilet Wall-Mounted EUROPEAN VERSION with GroheDal -D10013 Questions & Answers
Grohe toilet air button flushers not working
I'm going to just take a wild guess here based on what you said. I have never worked on one of these so bare with me. Your description is good and I think you have some sort of an air lock. I really think that if you just keep fussing with it, it will start working. Check the water inlet as best you can and keep trying to flush and see what happens.
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Re. Duravit Happy D toilet (tank No. 0929100005)
Remove and clean the flush valve and the flush valve seat(it is the flap that opens up to allow water to flush the toilet). Once the edges of the valve and the seat are cleaned, possibly with "0000" grit bulldog steel wool, it should not leak anymore. To make sure it is not leaking, once tank has refilled completely, put some food die in the tank. If, after 10-15 minutes, the water in the toilet bowl is colored, you have a leak from the flush valve. Replacing the flush valve is very easy - just bring the old one with you to the hardware/plumbing store and ask for a replacement. Blessings and good luck!!
10/5/2017 4:34:53 AM •
Duravit Home
Answered
on Oct 05, 2017
