20 Most Recent
American Standard 2383.014.165 Silver Cadet Cadet Two Piece Elongated Toile Questions & Answers
Add toilet shower and sink in attic space-to 4
Using a vent as a drain is not a good idea.The vent prevents backing up due to air pockets in theat section of drainpipe and obnoxios fumes will escape through the shower frain vithe possibility of creating an undesireable odor throughout the home.. Consult with a plumber befor using a vent as a drain, Ther e may be a building code issue. Good Luck, I understand your idea, but, I recommend specialized advice. Good Luc
11/5/2009 12:10:33 AM •
American...
Answered
on Nov 05, 2009
Air switch randomly comes on by itself and I have to leave the breaker off
This could be caused by a faulty relay or switch in the control panel. It is best to have a qualified technician inspect the control panel and replace any faulty components. If the issue persists after replacing the faulty components, then it could be a wiring issue and a qualified electrician should be consulted.
2/22/2023 9:40:24 PM •
American...
Answered
on Feb 22, 2023
My American standard champion 4 sings after I flush it, while it I still filling. Then stops when filled.
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
7/12/2019 12:28:16 PM •
American...
Answered
on Jul 12, 2019
