20 Most Recent American Standard 2860.334 Enfield Two Piece Toilet Questions & Answers
Depending on how many pipes you have connected in the run from the toilet to the concrete pipe, I would replace all of it with plastic pipe and a new soil pipe if I could find one, if not put the plastic in the soil pipe and pour a concrete patch to fix the hole. Without seeing what you have there, it is hard to say for sure. But cast iron is not used much these days and a job to fix, cut, seal, repair, most are replaced. Hope this helps.
American... | Answered on Mar 06, 2015
Are you on a well or city water? Septic tank shouldn't matter as it is below the level of the water in the toilet. It is coming from the fill water.
American... | Answered on Nov 11, 2013
There are a few likely causes for a toilet to leak and refill. The most common is the flapper not seating properly. Usualy on an American Standard it is a disc. Either way, they are fairly easy to replace. One test I use to see if the leak is comming from the flush assembly is to put a couple drops of food coloring in the tank and wait a few minutes to see if it appears in the bowl. If so, there is a leak in the flush assembly, usualy the flapper. Hope this heps. Please vote to let me know.
American... | Answered on May 13, 2010
They wanted your cc for this?? Are you sure weren't in another dept? I know they pay for answers, but I didn't know they charge for everything. There is a ton of people out there writing to this thing, I'm amazed by some of the questions. It looks like they posted your thing without the cc anyway.
American... | Answered on Feb 22, 2010
****if its the tank supply line and one of the connections is leaking tighten the connection if stops done if continues to leak go to hardware ,home,or plumbing store for replacement $4-7 dollars turn shutoff valve off flush toilet to get most water out of way and disconnect line replace ****----if joint where valve is connected to main water feed if threaded try tightening connection if soldered will need to turn of water to bathroom or house and drain line and resolder connection same of pressure connection/threaded valve failure
American... | Answered on Jan 25, 2010
More than likely the chain for the flapper is getting underneath the flapper. Shorten the chain length to avoid this. If that does not solve your problem then make sure the flapper is aligned properly with the hole. If it is off just the slightest it will not fully seal.
American... | Answered on Jan 02, 2010
With the toilet clean, try a large shop vac and see if that will unplug it , I had to do that when my son had flushed a toy and it was stuck. If that wont work you will have to pull the toilet.
American... | Answered on Oct 26, 2009
If you haven"t already got one, It would be my pleasure.
American... | Answered on Sep 28, 2009
Replace the flapper
American... | Answered on Sep 26, 2009
sometimes theres caps on top pop the cap and tighten the screws and sometimes there are nut or wing nuts on the bottom...simple enough for you?
American... | Answered on Sep 06, 2019
Depends how old your toilet is, it may be a calcium build up problem on your little inlet pipe inside your tank, but first check your water shut off valve on left side of your toilet near the wall....It may not be open all the way OR the valve has an issue...
American... | Answered on Jul 12, 2019
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
First, carefully remove your tank lid, and place it where it won't break or fall. Look for a four-digit number located on the back of the tank, near the water level mark. This is your tank model number. If the number starts with a two, it is a one-piece toilet.
Then....visit this link:
https://www.americanstandard-us.com/parts-support/faqs/toilets
Good Luck!
American... | Answered on May 06, 2019
More likely the sensor has malfunctioned.
American... | Answered on Nov 24, 2018
these are called phantom flushes. the water is slowly leaking around flapper or the is a scratch of the flapper seat. I use fluidmaster parts
American... | Answered on Nov 12, 2018
Toilets wear out from mineral deposits. Fixn may cost more then new. Googl used commodes first
American... | Answered on Nov 04, 2018
American Standard 2860.334 Enfield Two Piece Toilet Logo
Popular Tags
9 questions posted
Top American Standard Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you an American Standard Home Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Home
Most Popular Question
say service free when s not
  • Home
