20 Most Recent Leviton 500W - 6512H-I - Ivory Questions & Answers
Manual for a Leviton 9D35
https://www.youtube.com/watch?v=FdwvDJGrbK8
11/5/2022 1:41:12 PM • Leviton Hardware... • Answered on Nov 05, 2022
2answers
I have a VPT24-1PZ 24
The timer lets you adjust the preset astronomic time for your area.
This is because actual local times vary.
If the preset time for dusk is 8:00pm and you add 12 minutes, then the timer will turn off-or-on at 8:12.
And then you can change the preset time for dawn by adding or subtracting.
If this is not what exactly you are asking, then set your timer and see what happens, and then add a comment with your findings.
Open following link to download on-line manual
http://waterheatertimer.org/Leviton-timers.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
5/10/2022 6:16:50 PM • Leviton Hardware... • Answered on May 10, 2022
Have a 5 10 15 30 leviton timer to bath fan. switch is now buzzing though had been fine. what's going on.
The Leviton LTB30 20 amp timer has a known design flaw. It has a 1 microfarad electrolytic capacitor installed against a screaming hot resistor. Cooks and dries out the cap even when not in use. 50% failure rate in my initial install of 4 units. Pull it apart and replace the electrolytic with a ceramic cap and it will be fine. I have two of many that have already failed. Poor design of voltage regulation and poor layout of cheap components that self destruct. Design is not half baked, it is fully baked, lol. Can be fixed though, so not all bad...
11/26/2020 5:27:34 PM • Leviton Hardware... • Answered on Nov 26, 2020
To program vizia leviton 24 hours on and off
Leviton timer manuals appear following link: http://waterheatertimer.org/Leviton-timers-and-manuals.html
11/3/2019 10:31:07 PM • Leviton Hardware... • Answered on Nov 03, 2019
How do I programme my Leviton Decora timer 10/24
The following link has manuals for Leviton timers: http://waterheatertimer.org/Leviton-timers.html
10/11/2018 6:10:27 AM • Leviton Hardware... • Answered on Oct 11, 2018
Installing Leviton 5601 single pole switch to replace an old timer switch. The box has two black wires and one white wire. How do I connect to Leviton switch?
Dear Dean, Generally speaking, black indicated "hot", like the color of "burnt". White indicates the color of ground. ( ice or snow) One of your black wires should be "incoming" ( that means have electricity in it NOW", and the other one would go to where the item was that was timed. After you find which wire is "hot", the other black wire goes to the opposite side of the switch. You may need to reverse the black wires if it is wired backwards to the ":on" & "off" readings. The ground would be the white wire. If you have a green screw, the ground (white) could go there.
3/20/2017 7:52:32 PM • Leviton Hardware... • Answered on Mar 20, 2017
0answers
0answers
0answers
I instaled a timer Leviton
1) To test the timer, put it on another Load, for example a light.
2) Also you can test your wires.
Take wire nut off Black-black connection and test to bare ground >>> tester should light up.
Next take wire nut off Black-blue connection and test to bare ground >>> tester should NOT light up until push button is activated and countdown begins.
3) Another thing to try is reversing the blue and black wire, just to double check your wiring.
1/5/2011 8:07:13 AM • Leviton Hardware... • Answered on Jan 05, 2011
I have a Lithonia dusk to dawn flood light that's brand new there's also an on off switch. What does the on off switch control and for dusk to dawn should it be on or off?
  • When the switch is ON, the light operates in dusk-to-dawn mode. In this mode, the light automatically turns on at sunset and turns off at sunrise. When the switch is off, the light stays off.
4/18/2024 7:13:42 PM • Hardware &... • Answered Yesterday
2answers
Grasslin QE7+ water heating timer dial problem
motor or gear failure
3/12/2024 10:39:33 AM • Hardware &... • Answered on Mar 12, 2024
Leviton 500W - 6512H-I - Ivory Logo
0 questions posted
Top Leviton Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Leviton Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Leviton Hardware & Accessories
Most Popular Question
leviton programmable timer 6124h w
  • Hardware & Accessories
