20 Most Recent First Alert 24 Hour Timers - 2 For The Price Of 1 Questions & Answers
2answers
I have a First Alert
I came across this page while looking for the same thing. Then I found the manual! I scanned and uploaded it to Photobucket. Click on the link to view. I know the original post is from a couple years ago, but hopefully this can help someone trying to remember how to program this timer.Click Here For The Owner's Manual
12/12/2019 10:16:45 PM • First Alert 24... • Answered on Dec 12, 2019
Need instructions to set the First Alert TM220
For the Model TM-220, 24 hour timer set as follows: 1. Begin with all timer segments on the dial 'pushed up'. 2. Push 'down' the segments required for the 'ON' time; each segments represents 1 hour. 3. Rotate the dial clockwise until the 'TIME NOW' aligns with the pointer.
11/18/2014 6:30:24 PM • First Alert 24... • Answered on Nov 18, 2014
0answers
0answers
Programming noma 16usw/et
http://waterheatertimer.org/How-to-set-timers.html Gene h If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
12/11/2013 11:10:33 PM • First Alert 24... • Answered on Dec 11, 2013
2answers
I have several LS220 24
I don't know LS220 timer, and internet search turns up no legit information.
I suggest 4 possible solutions:
1) If this is a dial timer with segments, and you pull these segments up to set on-off times: work-around for missing segment is to switch am and pm hours. Fresh set of un-used segments exist on opposite side of dial.
2) Add a comment with clear description of timer.
I will check my files against timers that have replaceable trippers
Specific Intermatic and Tork timers have replaceable tripper parts.
Trippers are available on heavy-duty timers that generally cost more.
3) Identify your timer or similar timer on following link, and then add a comment and I will respond.
http://waterheatertimer.org/Woods-timers-and-manuals.html
4) If this timer costs $20 or less, Buy another timer since it would be cheaper than ordering off the internet and paying S&H.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
10/8/2013 1:18:21 AM • First Alert 24... • Answered on Oct 08, 2013
0answers
Directions for first alert timer model 24T2
First alert 24-hour analog timer has segments located around the dial.These segments are lifted using a finger.Copy following link to see how to set analog timers by experimenting with features;http://waterheatertimer.org/How-to-set-timers.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/21/2012 2:35:00 AM • First Alert 24... • Answered on Jul 21, 2012
0answers
Have a first alert et220
Timer is not identified for certain. Expert does not have instruction manual and can only guess at cause of problem.
For example not all timers are rated for CFL or halogen bulbs.
Loose light bulb filament, or loose light bulb, or dirt in light bulb socket can cause problem, replace light bulb.
Conflicts in timer programming can cause problem with digital timer.
Read more options listed below:
1) Add a comment and describe timer appearance and if timer is programmable or has a rotary dial.
Describe what buttons appear on timer.
2) Take photo of timer and post on flickr and add comment with link to that photo.
3) Scan your timer instructions into file format. Post this file to Flickr and then add a comment with link to those instructions.
12/9/2011 3:31:34 AM • First Alert 24... • Answered on Dec 09, 2011
I cannot set up my
Timer is not 100% identified.
Add a comment with in-focus photo of timer posted on flickr.
My records show that First Alert TM241 is 24-hour plug-in analog timer with plastic segments located around edge of dial. Use finger to pull up the segments.
Open following link for ez instructions for setting analog timers.
Add a comment for more help
Upvote the help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
12/9/2011 2:00:31 AM • First Alert 24... • Answered on Dec 09, 2011
I can not get the timer to come on at the correct
Your timer could be broken.
But let's review.
Override set atTimer on > correct
When override is moved other direction, then lamp turns on.
Lamp fixture is turned on
Bulb is good
Receptacle has power
You tied timer on different lamp at a different receptacle.
Dial rotates with passing time, which indicates that clock motor is functioning
Dial does not get stuck during rotation, and makes complete 24 hour circuit in 24 hours, indicating that clock motor is not weak.
Segments up or down for timer functions >> here's what to do: pull up some segments. Manually rotate timer dial clockwise.
The lights will turn on-off as you rotate dial manually.
That will confirm if up or down is correct position of segments.
If everything above checks out, timer should work.
If timer is defective, exchange for another one.
I test these timers and 4-6% arrive defective. Most last one or two seasons and then they quit.
Some last years.
But timers today are priced low enough.
12/2/2011 10:35:12 AM • First Alert 24... • Answered on Dec 02, 2011
How do you set the time on timmer
Question posted under analog timer. http://waterheatertimer.org/How-to-set-timers.html
10/6/2011 11:26:36 AM • First Alert 24... • Answered on Oct 06, 2011
HOW DO YOU SET UP
Solution posted at:
http://www.fixya.com/support/t1329823-first_alert_timer_et220
1. Set time: Rotate dial (PM indicated by PM light) Stop at current time. Press Time set button.
2. Rotate dial to desired ON time; press & hold On/off button, rotate dial to OFF time, release On/off button
3. To Cancel the time. Press & Hold on/off and rotate one cycle to erase.
And will have to reset time (1)
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
9/11/2011 2:34:12 AM • First Alert 24... • Answered on Sep 11, 2011
I have the first alert
Question does not describe the timer.
Web search for et220 does not show image of timer for clear identification.
My files do not show et220
Question posted under 24-hour analog timer.
1) Open following link for possible instructions:
2) Add a comment with clear description of timer for possible identification and instruction manual.
3) Post a photo of the timer on Flickr. Add a comment with link to photo for possible identification and instruction manual.
4) Maybe possible to e-mail the company for instructions: [email protected]
9/8/2011 11:08:28 PM • First Alert 24... • Answered on Sep 08, 2011
I forgot how to set it ,
Timer is not identified.
Add a comment with clear description of timer for possible help.
If you have analog dial-type timer, open following link for instructions:
7/8/2011 12:28:41 AM • First Alert 24... • Answered on Jul 08, 2011
FIRST ALERT TIMER TYPE
Timer is not identified. Web search does not show photo of timer.
Guessing you need help setting timer?
1) Open following link for 8 different photos of segments/pins that are located on dial of analog plug-in timers, and instructions how to set analog timers.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
2) If information above does not include your timer, then look down the full page on link above and find same-similar timer with instructions. Add a comment at any time.
3) Also add a comment with in-focus photo of your timer posted on Flickr so expert can identify timer for sure. Then include exactly what problem you are experiencing and what you have done so far to fix problem.
Upvote the help.
And take advantage of fixya expert assistance live.
5/16/2011 11:41:01 PM • First Alert 24... • Answered on May 16, 2011
First Alert 24 Hour Timers - 2 For The Price Of 1 Logo
40 questions posted
Top First Alert Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a First Alert Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • First Alert Hardware & Accessories
Most Popular Question
first alert
  • Hardware & Accessories
