20 Most Recent
Lucien Piccard 26321 Wrist Watch Questions & Answers
Changed power cell and watch still not running
Movements become "dry" over time and must be serviced.
Another common problem we see is that there is oil or battery acid (from a previously leaking battery) inhibiting proper connection between the contacts and the battery.
The quartz and the circuit itself may also go bad on a movement at any time.
If it is under warranty, you may send it back directly to Lucien Piccard.
I recommend you visit your local Certified Master Horologist for what is usually a free diagnostic. They can test the battery, the connection, the movement, and usually repair, service, or replace the movement for you. They will also generally give a free estimate.
I received a lucien piccard vd53 watch and can't get it to run.What do I do to start it??
I see your watch has a Seiko VD53 Quartz Chronograph Movement. Several possibilities come to mind - the watch may have a small plastic spacer under the crown which is there to stop the battery running flat before the watch is sold. If that's the case then simply remove the spacer and press the crown in. Possibly, the battery is flat and will need replacing, or you've received a faulty watch - either way (and I interpret your using the word 'received' as meaning that it was a gift to you) you should tactfully point this out to the giver. They wouldn't want to have wasted their money, and hopefully they've kept the receipt.
Value for 28116BK
about $100.
Lucien Piccard is a brand with distant Swiss heritage, which now has the same address as Invicta, SWI group, Stuhrling/Akribos and World of Watches. Asian manufacture and always a deep "discount" from list price. This isn't to say that they don't have some great looking watches, only intended as a bit of background to the company.
