20 Most Recent
Square D Co. QO120CAFIC ARC Fault Circuit Breaker Questions & Answers
20 A AFCI Homeline trips
You should not have multiple GFCI devices in any one circuit. Change out the outlet and label it
GFCI Protected if necessary...Your problem of nuisance trips should go away.
John
Have a dorm with arc
Try this! Do a amp load test on that circuit..Make sure everthing is on when you do the test...
Square D circuit breaker in a home fuse panel and I have already replaced the breaker with a new one.
i strongly recommend that you get in an electrician to investigate the problem
from your description of the amount of power required from your circuit breaker I would consider that there are to power wires from the back of that unit
one circuit to run half the points and another wire to run the rest
If only 1/2 are working, I am thinking that one of the wires at the back of the breakers is loose or come undone/broken and that will require the services of an electrician
To further explain this line of thought, each circuit in a house is designed to carry a maxim of 10 amp total (wire current capacity) so that with all outlets in operation the maximum current is 10 amps
if the required current allowed exceeds that the electricians break the numbers up so that a second circuit is employed again up to 10 amps max
if again there was a requirement that exceeded the 20 amps ( circuit breaker amp) a second circuit breaker would be installed and a 3rd circuit and so on
3/31/2017 1:55:10 PM •
Square...
Answered
on Mar 31, 2017
On a 60 FT. run using 12/2/G wire can I use a 25amp. breaker safely?
The size of the breaker that you are going to use on a circuit is predicated on the current draw of the appliance(s) you have on the circuit. Assume you have them all turned on, add up their respective amperages and , voila, you have a close approximation of the size of the breaker. If you do not know the amperage look for watts info. Divide the latter by voltage of 115 and you will arrive at the amps used.
9/25/2015 5:02:51 PM •
Square...
Answered
on Sep 25, 2015
Electrical panel dead, main and all breakers
Then, call PG&E...or your local utility company to come out and check your meter. PG&E, or your local utility company are responsible for the power up to the meter at your electrical service panel. After that, it's the electrician's responsibility...
7/1/2014 8:18:25 AM •
Square...
Answered
on Jul 01, 2014
