20 Most Recent KitchenAid KHHS179LSS Convection / Microwave Oven Questions & Answers
Microwave high intensity light turning bright orange
You have a shorted grille relay on your control board. I can repair this for $69.95, which includes insured return shipping. For details and more free DIY and other help & advice, feel free to contact me. William E. Miller, AS-EET [email protected] http://www.microwavecontrol.com Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
3/16/2017 8:48:33 PM • KitchenAid... • Answered on Mar 16, 2017
I cant get the screws out of the back of my microwave how do i go about this
Magnetic screwdriver with extended shaft. If you have chewed the screws get a screw removal bit and use a torque driver.
5/13/2014 3:44:58 AM • KitchenAid... • Answered on May 13, 2014
3answers
Dead Microwave - Internal Fuse?
After replacing the internal fuse (see other posts to see how I did it) the microwave is working fine (so far). We have used it 5 or 6 times without any issues.
5/13/2014 3:24:42 AM • KitchenAid... • Answered on May 13, 2014
0answers
0answers
Replace light
Be the first to answer 1/28/2014 4:30:29 PM • KitchenAid... • Posted on Jan 28, 2014Be the first to answer
Not heating
Check the hi voltage fuse. It's located near the klystron tube.
1/5/2014 10:28:47 AM • KitchenAid... • Answered on Jan 05, 2014
Replace inverter board KHH179LSS2
see the video attached. and fix it. God bless you
10/28/2013 12:32:01 PM • KitchenAid... • Answered on Oct 28, 2013
Step-by-step replace inverter board
see the video and fix it. GOD BLESS YOU
10/28/2013 12:25:28 PM • KitchenAid... • Answered on Oct 28, 2013
How do I safely discharge the capacitor before
SEE THE FIGURE AND PROCEED ACCORDING. GOd bless you847e1cca-29c6-4be1-8cd5-b7429ffcd5f1.gifremember try that the screwdriver can be isolate it.
10/28/2013 12:15:17 PM • KitchenAid... • Answered on Oct 28, 2013
0answers
What is Error F7
I am having the same problem. According to the owner's repair guide error Code F7 indicates that power to the magnetron was interrupted. You will want to make the following checks: 1. Unplug microwave oven or disconnect power. 2. After 40 seconds, check to see whether this solves the problem. 3. Unplug microwave oven or disconnect power. 4. Check resistance of the magnetron thermostat. 5. Check the magnetron. 6. Check wiring to the 1100W inverter and control system. See "Checking Inverters." 7. Plug in microwave oven or reconnect power. 8. Check operation of all interlock switches. Check door, hinge and cavity front alignment. Adjust as needed. 9. Unplug microwave oven or disconnect power. 10. If switches operate correctly, replace 1100W inverter. 11. If problem persists, replace electronic control. 12. Plug in microwave oven or reconnect power. While this is helpful, it is still out of my confort zone as I pulled the control panel and discovered a virtual zoo of connectors. Obviously ponly a trained repairman knows which ones need to be checked. I will probably have to resort to calling one and shelling out the dough.
7/19/2013 2:10:53 PM • KitchenAid... • Answered on Jul 19, 2013
0answers
I have a FMT116E1W made a loud pop and now no power or anything.
This sounds like the magnetron has failed, the pop sound is a classic sysmptom.
5/19/2012 3:22:45 PM • KitchenAid... • Answered on May 19, 2012
My KHHS179LSS Kitchenaid microwave acts like it
Hello & Welcome to FixYa
Check this image for your Microwave parts, part#25 and part#29 are two thermal fuse. If both of them are fine then it is the electronic control that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
10/15/2011 4:30:46 PM • KitchenAid... • Answered on Oct 15, 2011
KitchenAid KHHS179LSS Convection / Microwave Oven Logo
67 questions posted
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Microwave Ovens
Most Popular Question
kitchenaid khhs179lss 1100 watts r ni
  • Microwave Ovens
