20 Most Recent KitchenAid KCMC155J Convection/Microwave Oven Questions & Answers
KitchenAid KCMC155J 1000 Watts Convection / Microwave Oven - how to change the light bulbs - can this be done without having to call a tech?
The service number for this microwave is 1-800-422-1230. I have seen this question posted on several sites with no answers. Also, I checked the Owner's Manual and I do not see an answer to this question. If I had to guess, I would say that if there is no access from the inside of the microwave, you may have to remove it from the wall as the access might be on the back of the unit.
4/14/2016 8:47:21 PM • KitchenAid... • Answered on Apr 14, 2016
How do I change the light bulb in a KCM155j Mircowave
Most microwaves have a shield over the light bulb in the cooking compartment. Some are accessed from the outside most from the inside. Check to see if there are clips or screws that need to be removed to pull the shield off. Careful if there are screws, they are usually coated to prevent the waves from arcing if you crack or break off the coating you could have problems with the microwave arcing
1/11/2014 7:22:54 AM • KitchenAid... • Answered on Jan 11, 2014
0answers
0answers
Unit starts running when door
Check the door interlock switches and condensation on the control panel.
1/16/2011 4:15:40 PM • KitchenAid... • Answered on Jan 16, 2011
No longer heating up on
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....Microwave Oven Basic Troubleshooting Tipsheatman101
1/9/2011 3:52:11 AM • KitchenAid... • Answered on Jan 09, 2011
0answers
Triping breaker as soon as it is plugged in.
try pluging it in on another outlet with an extension cord must be a diffent cerciut breaker if it happens again the microwave has a short. if not its that breaker or outlet.
5/8/2009 5:25:18 AM • KitchenAid... • Answered on May 08, 2009
2answers
KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
12/23/2007 8:02:50 PM • KitchenAid... • Answered on Dec 23, 2007
Kitchenaid microwave kmhs120ess door fell apart
Doors for microwave ovens are usually replaced as a complete item. I would ask the person who forgot to fix the door latches properly back to fix it properly. If some of the clips were snapped off when removing the door panel, the panel must be replaced or it will fall out again.
2/11/2024 9:28:54 AM • KitchenAid... • Answered on Feb 11, 2024
Kitchenaid oven racks fall
I am a bit late on this question, but just ended up in a rabbit hole of unanswered Kitchenaid questions The self cleaning features only serves to keep manufacturers in steady sales of parts. Quite simply the oven can only take those temperatures a few times until they break. The heat burns out elements, damages fans, door locks and worst of all damages control boards which are not far enough from the heat source. You problem sounds like the walls of the oven have buckled in the heat so the racks no longer fit. Too late now, but you should have taken Kitchenaid to court, the oven was not fit for purpose under the description they used to sell it to you. Never use the self cleaning feature as stated here https://www.google.com/search?q=self-cleaning+oven+temperature Never Ever use the self clean feature. We see damage here every couple of weeks. The worst was a burned control board on an oven that all parts were obsolete, so the self clean cost a thousand bucks! Self-cleaning ovens bring the heat so you don't have to spend hours scrubbing. Traditional self-cleaning cycles heat the oven between 800°F and 900°F, helping turn soil and spills to a powdery ash you can then wipe away. They utilize only heat-no chemicals-and are built to withstand high temperatures. (Says Maytag who love selling elements, door locks and other parts),
Why You should Never Run A Self Clean Oven Cycle & ...
General Appliance Servicehttps://www.generalappliancesvc.com > why-you-shou... Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or ...
Self-cleaning oven
Wikipediahttps://en.wikipedia.org > wiki > Self-cleaning_oven A self-cleaning or pyrolytic oven is an oven which uses high temperature (approximately 932 °F (500 °C)) to burn off leftovers from baking, without the use ... ‎Pyrolytic process · ‎Alternative technologies · ‎Catalytic cleaning
Self-Cleaning Oven: 6 Reasons to Stop Using Feature ...
FIX Appliances CAhttps://fixappliances.ca > 4-reasons-stop-using-self-cle... A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters at an extremely high temperature (932 F° or 500 C°) to aid in ... ‎How Self-Cleaning Ovens Work · ‎Major Parts Damage ..
1/16/2024 4:40:22 AM • KitchenAid... • Answered on Jan 16, 2024
My KitchenAid oven/microwave combo KEMC377KSS05 control panel not working. how to check what is wrong?
Open the control panel using this diagram Official KitchenAid KEMC377KSS05 wall oven/microwave combo parts ' Sears PartsDirect Check the cables and connectors. If Ok then problem is in cuicuit board.
10/18/2023 1:27:43 PM • KitchenAid... • Answered on Oct 18, 2023
KitchenAid Superba KEMC308KSS0 Microwave oven acting like we're having repeated powerline brown-outs, but we're not.
There is a huge capacitor inside microwaves, and that description sounds like it is starting to fail. There are smaller capacitors as well. It won't be a door switch, they work or they don't. I had two Panasonic Commercial microwaves in a pub kitchen, one plain and one was a combination machine and both had drop down doors.
5/20/2022 1:57:13 AM • KitchenAid... • Answered on May 20, 2022
KitchenAid KCMC155J Convection/Microwave Oven Logo
23 questions posted
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Microwave Ovens
Most Popular Question
unit starts running when door
  • Microwave Ovens
