There is no reset other than unplugging the power for a minute then plugging it back in.If this in under warranty I would contact the manufacturer via the information in your owner's manual for a free repair.If for some reason you don't still have yours, you can
download Kitchenaid / Whirlpool owner's manuals and installation
instructions here.If it's out of warranty, we repair these controllers for $39.95, or you can order an LCD assembly (part number ) from the Pros here or get a refurbished unit from us here.We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
I was afraid I needed to replace the microcomputer when my KHHS179L touchpad was unresponsive. I was able to use the ADD A MINUTE feature, so I knew the unit worked. There had been a power outage of less than a minute to my home recently (I was unaware of this until I asked the kids if they had done anything to the microwave). I popped around on fixya.com and really didn't find an easy solution-my favorites. I loaded kitchenaid.com and found the answer in the FAQ's. Although the control lock out icon was NOT LIT-apparently, that power surge locked my controls. By holding the stop button for 5 seconds once and then aagain a second time, miraculously, my touchpad was restored> HOORAY!
what this code indicate on the screen is that there have been a loose wire connected to the element(heater) of the wave.
what you are to do to fix up this problem is to unscrew the wave the trace the wire down to the element the element is silver in nature or color fix up the wire back to the element and then see if the problem is solve, but if the problem remain then it means that you will have to replace the element
you can get the part at any good technician store around you but note this information make sure that the part you will order for should be same with the old one that need a replacement for easy compatible.
For model KHHS179LWH2, from the tech sheet located behind the controls or found online here:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power. 2. After 40 seconds, check to see whether this solves the problem. (Possible reason: Over temperature protection for the magnetron opened.) 3. See safety info here, then check resistance of the magnetron thermostat. It should be close to 0 ohms. 4. Check the magnetron. 5. Check wiring to the 1100W inverter and control system. 6. Check operation of all interlock switches. 7. If switches operate correctly: - Replace 1100W inverter. - If problem persists, replace power supply board. 8. Plug in microwave oven or reconnect power.
At
our Web site, we have a video available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You can find
links to helpful exploded view diagrams and part ordering help here.
We're
thoughtful rating of our answer.
