20 Most Recent
Troy-Bilt TROY-BUILT 91215 - TROY-BUILT 20416 Pressure Washer 5HP Gas 3000 PSI Gas Powered Questions & Answers
Gas leaks out side of pressure washer
Your washer was sitting for a while I suspect. Check the carb and make sure it is tight to the engine. If it is then you will need to take the carb off, careful not to tear any gaskets. Then remove the fuel bowl and clean out all ports. Make sure to clean out the jet as well as I suspect the fuel is clogged in the carb and overfilling. Your needle valve is stuck open and then flooding your carb and spilling out the side of your engine. Make sure your needle valve and float can move freely before reassembling. Good luck
2/26/2015 2:12:55 PM •
Troy-Bilt...
Answered
on Feb 26, 2015
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
11/1/2014 4:46:15 PM •
Troy-Bilt...
Answered
on Nov 01, 2014
Drive system not working
I'm not sure what you are expressing. Give us a call when you can be at the washer so we can diagnose it over the phone.
6/11/2014 4:03:32 AM •
Troy-Bilt...
Answered
on Jun 11, 2014
